![]() Join Date: Sep 2010
Cruise control with quick release
Hey guys I was looking to find a way to use the stock cruise control with a quick release. I searched on google to see if it pops up on any forums. I found some other guy asking the same question and somebody replied
"I removed the buttons from the steering wheel and relocated them to the bottom of the steering column. Quick and easy, no wire to run. Just poke a small hole in the plastic for the wires to go thru. Kinda stealthy, no one sees the buttons. I can snap a pic if you want." Well I pulled the column cover off and I have no idea where I would plug the stock three button in. If you guys have any ideas or suggestion it would be very helpful. Thanks
Personal IG: nic_giannini Club Sandwich IG: clubsandwichstreetteam |
Man w/ CTSV & a Car Seat
You'd have to rewire the white plug that goes into the cruise control bottons to the wires after the yellow plug on the steering column. Read the guide and itll tell you what wires are which.
I figured it out. Gained cruise control and looks and works great but now my horn doesn't work.
