![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 9 reviews
GKTech - S13 and S14 Oil Catch Cans
S13/180sx Over The Radiator Oil Catch Can - Polished
The GKTECH over the radiator oil catch can is manufactured from stainless steel and is a direct fit on the standard radiator fan shroud. The catch can has a baffle plate between the inlet and outlet to ensure splashing of oil out the outlet port is kept to a minimum. 1.68L capacity. Vehicle Compatibility: - Nissan S13 Silvia (SR20 only) - Nissan 180sx (SR20 only) NOTE: for S14/S15 oil catch cans refer to our other listings NOTE #2: Can ONLY be used if you're not running the standard style intercooler cross over pipe. Price: 69 AUD (approx. 59 USD) Shipping cost: From 61 AUD (approx. 58 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/s13-...-polished.html S13/180sx Over The Radiator Oil Catch Can - Black The GKTECH over the radiator oil catch can is manufactured from stainless steel and is a direct fit on the standard radiator fan shroud. The catch can has a baffle plate between the inlet and outlet to ensure splashing of oil out the outlet port is kept to a minimum. 1.68L capacity. Vehicle Compatibility: - Nissan S13 Silvia (SR20 only) - Nissan 180sx (SR20 only) NOTE: for S14/S15 oil catch cans refer to our other listings NOTE #2: Can ONLY be used if you're not running the standard style intercooler cross over pipe. Price: 69 AUD (approx. 59 USD) Shipping cost: From 61 AUD (approx. 58 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/s13-...n-black-1.html S14/S15 Over The Radiator Oil Catch Can - Polished The GKTECH over the radiator oil catch can is manufactured from stainless steel and is a direct fit on the standard radiator fan shroud. The catch can has a baffle plate between the inlet and outlet to ensure splashing of oil out the outlet port is kept to a minimum. 1.68L capacity. Vehicle Compatibility: - Nissan S14/S14a 200sx - Nissan S15 200sx NOTE: for S13/180sx oil catch cans refer to our other listings NOTE #2: Can ONLY be used if you're not running the standard style intercooler cross over pipe. Price: 69 AUD (approx. 59 USD) Shipping cost: From 61 AUD (approx. 58 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/s14-...-polished.html S14/S15 Over The Radiator Oil Catch Can - Black The GKTECH over the radiator oil catch can is manufactured from stainless steel and is a direct fit on the standard radiator fan shroud. The catch can has a baffle plate between the inlet and outlet to ensure splashing of oil out the outlet port is kept to a minimum. 1.68L capacity. Vehicle Compatibility: - Nissan S14/S14a 200sx - Nissan S15 200sx NOTE: for S13/180sx oil catch cans refer to our other listings NOTE #2: Can ONLY be used if you're not running the standard style intercooler cross over pipe. Price: 69 AUD (approx. 59 USD) Shipping cost: From 61 AUD (approx. 58 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/s14-...can-black.html For any inquiries please e-mail us at [email protected]. |
