93 Blacktop SR Swap boost problem
This is the set up I have in my 93 s13 240sx. I have a Type X S13 Blacktop SR with and upgraded tube manifold and S14 T28 turbo (came like this from japan). So this is how I have my vacuum lines set up
Top Left @ Throttle body - FPR and Boost Gauge Top Right @ Throttle body - BOV and wastegate Bottom Left @ Throttle body - Capped off Without a boost controller inline before the wastegate my car makes about 15-16PSI With a ebay MBC inline before the wastegate (completely closed) my car still makes about 15psi. Why is my car making so much boost? Do I have a vacuum leak? Should I invest in a EBC? Oh also my car wants to die when it starts up from a cold start |
watch your air/fuel ratio to make sure you are not running super lean.
Not sure why you've got so much boost. could be a vacuum leak. not sure.
93 Hatch w SR20
Man w/ CTSV & a Car Seat
Sounds like you got an aftermarket wastegate. Get an adjustable air compressor, hook up the compressor to the wastegate line and slowly bump the pressure on the compressor and see when the flapper opens up. Stock wastegate should open around 7 psi.
okay I'll do the pressure test on the wastegate and I'm going to replace the vacuum line with silicone ones. I'll take a picture of my vacuum line set up and post it up so you can see if I have it wrong. but for the time being I'm just not letting the car boost past 10psi
i am stuck with the same problem and ive swapped in between known working oem wastegate and an hks adjustable still no fix. just keeps boosting at 11-12psi with a single vacuum from my hot pipe??? so if you figure this out let me know thanks. i also heard someone speaking of back pressure as a result of boost peak?
okay found out my wastegate isn't opening. so that's why it is boosting so high. I'm gonna go pick up a new garrett wastegate at z1 motorsports tomorrow morning. hopefully this fixes the problem. now in search of a decent priced starter. because mine is crapping out.
