Closed Thread
Old 01-08-2009, 03:30 PM   #1
Hawaiian240
Hawaiian240's Avatar
Hawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud of
s13 Lots of stuff for sale!!
Some left over stuff from my other thread(now closed) and more, MORE, MORE!
All prices do not include shipping unless otherwise stated. I accept cash or Paypal only.
My paypal is [email protected] there is an "underscore" between perez and amy.
Money talks, so unless I see payment.......you do not have the item. If you agree with the price, tell me when you can pay, or it may go to someone else.
I am in the Goose Creek/ Charleston area.
PM or email me for faster response!!
S13 DIN pocket $10.00
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 154KB.
Some suspension stuff RUCA, tension rods and traction rods. All for $45.00 shipped. Individual sets listed below.
All Energy Suspension bushings are the black ones. I think they are the higher durometer stuff, more stiff than the red bushings, but I have been wrong before!!!
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 156KB.
S13 OEM tension rods $16.00 shipped
Comes with Energy Suspension bushings(pictured), NOT installed!
OEM rubber bushings are shot
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 172KB.
S13 OEM Rear Upper Control Arms $16.00 shipped
S13 OEM Traction Rods $16.00 shipped
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 186KB.
25mm/ 4 x 114.3 spacers, brand unknown. Comes with nuts and hubcentric rings for S13. Bought this from another Zilvian a while back. <<<<<<<<<<<SOLD TO proughj>>>>>>>>>>>>>>>>>>>
S13 OEM front caliper setup. Calipers probably need to be rebuilt, comes with everything pictured. $25.00 shipped
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 166KB.
S13 USDM steering wheel 10.00
S13 Instrument Cluster bezel/trim w/ following switches: hazards, rear window defroster, dimmer lights(doesn't work well) and coin holder <<<<<<<<SOLD to k0uki>>>>>>>>>>
KA24DE pistons from a '95 S14 w/78k miles. 25.00 shipped
Sides of skirts have some wear.
Ring lands are still good, comes with original rings too HAHA!
Comes with pins, but 2 of the retaining clips are missing.
Tops
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 148KB.
Bottom
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 150KB.
KA24DE crank girdle, NO BOLTS. I have 2 of these. No scoring on the journals. 15.00 each
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 139KB.
If it's good for something............ a KA24DE crank with pully key groove damaged(see 2nd pic). Journals are still good but NO KEY! FREE!! You just pay for shipping, or come and pick it up!
Maybe you can use it as a paper weight or something!!
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 153KB.
Fixable?????
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 159KB.
KA24DE bare block. 50.00
Decked, honed, tapped for turbo oil(supply and drain, explained below) and cleaned at S&R machine shop(Summerville, SC).
Light surface rust on machined surfaces. Was going to use this for a rebuild, but rebuilding my other block instead.
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 169KB.
Oil supply tap at oil pump journal. 1/4" NPT
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 171KB.
Oil drain tap(drivers side just forward of bellhousing) 1/4" NPT.
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 165KB.
S13 output shafts, 6 bolt. DOES NOT COME WITH RETAINING CLIPS OR BOLTS pictured!! 25.00 shipped
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 173KB.
Vortech Engineering 6:1 FMU. 65.00 shipped
New at Summit for 167.95!
Setup for Ford mustang with 36 lb/hr injectors.
You can order different shims(from Vortech) to change ratio(about $40.00).
Comes with mounting bracket, about 24" hoses with weird fittings that I have not seen before!
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 160KB.
Hoses
Weird fittings!
This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 184KB.
S13 5spd OEM driveshaft w/ carrier bearing 20.00 Really heavy, so shipping will be a bitch!
VLSD w/5 bolt output shafts and half shafts(with nuts and bolts).
Guy I bought it from said the VLSD came out of a '97 S14.
*DOES NOT COME WITH COVER, I will be using it for my Nismo 1.5way.
*When I took this out today, the drivers side half-shaft was partially stripped(third pic). I think you can still rethread it.
50.00Really heavy, so shipping will be a bitch!
Half-shafts
Stripped end
FOLLOWING ITEMS ARE STILL ON CAR. I HOPE TO GET THEM OUT TOMORROW, WILL POST PICS LATER!
S13 OEM KA24DE radiator. No leaks, works great! 20.00
S13 OEM electric radiator fan. Good condition, bolts right in. Works flawlessly. 15.00
Have more stuff to get rid of, will post those later.
For Sale threads:
#/f/sale-items/33286...tons-pics.html
Review Thread:
#/f/private-sellers/...-chhheeee.html
TRADER RATING:
#/f/traderratings.html?u=66301
Hawaiian240 is offline
Old 01-08-2009, 04:04 PM   #2
P_856
P_856's Avatar
P_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really nice
are the tension rods bushings 1 piece or 2 piece?
P_856 is offline
Old 01-08-2009, 04:12 PM   #3
tramp_drift240
tramp_drift240's Avatar
tramp_drift240 is on a distinguished road
Send a message via AIM to tramp_drift240
two piece bushings?
they're press ins.
tramp_drift240 is offline
Old 01-08-2009, 04:17 PM   #4
nissansrdub
nissansrdub's Avatar
nissansrdub is an unknown quantity at this point
$10 for the DIN shipped? how much shipped to 92555? send me an email to [email protected]
nissansrdub is offline
Old 01-08-2009, 04:24 PM   #5
Hawaiian240
s13
Originally Posted by tramp_drift240 View Post
two piece bushings?
they're press ins.
They are actually 3 piece and a metal insert. I will post detailed pics later.
Email sent.
For Sale threads:
Review Thread:
TRADER RATING:
Old 01-08-2009, 04:31 PM   #6
Hawaiian240
s13
Here are the pics of the tension rod ES bushings
For Sale threads:
Review Thread:
TRADER RATING:
Old 01-08-2009, 04:45 PM   #7
P_856
P_856's Avatar
cool how much shipped to 08110
P_856 is offline
Old 01-08-2009, 05:43 PM   #8
Hawaiian240
s13
PM sent. Sorry, my kids are whiners tonight!
For Sale threads:
Review Thread:
TRADER RATING:
Old 01-08-2009, 09:49 PM   #9
proughj
Banned from the Marketplace
proughj is making a name for him/her selfproughj is making a name for him/her self
intrested in the spacers hm shipped to 94401?
proughj is offline
Old 01-09-2009, 04:56 AM   #10
Hawaiian240
s13
Another guy said he would pay for them today. But if that falls through, your next in line. PM sent.
For Sale threads:
Review Thread:
TRADER RATING:
Old 01-09-2009, 05:14 PM   #11
Hawaiian240
More stuff to sell! Original post updated with the following:
VLSD w/5 bolt output shafts and half shafts but NO COVER!
For Sale threads:
Review Thread:
TRADER RATING:
Old 01-10-2009, 05:30 PM   #12
Hawaiian240
s13
Updated with pics of driveshaft(with carrier bearing bracket), S14 VLSD(5 bolt) with half-shafts.
Buyers for DIN pocket and suspension items have backed out, so up for sale again!!
Taking out the OEM radiator and electric fan tomorrow, will post pics of those later.
For Sale threads:
Review Thread:
TRADER RATING:
Old 01-11-2009, 05:06 AM   #13
Hawaiian240
s13
Spacers are sold to proughj
Price drop on some of the other items!!
For Sale threads:
Review Thread:
TRADER RATING:
Old 01-11-2009, 09:32 AM   #14
racerx2k1
460
racerx2k1's Avatar
racerx2k1 is close to perfectionracerx2k1 is close to perfectionracerx2k1 is close to perfectionracerx2k1 is close to perfectionracerx2k1 is close to perfectionracerx2k1 is close to perfectionracerx2k1 is close to perfectionracerx2k1 is close to perfectionracerx2k1 is close to perfectionracerx2k1 is close to perfectionracerx2k1 is close to perfection
2 bump limit. You can start new thread in 3 days.
racerx2k1 is offline
Closed Thread
