Tons of 240sx parts.
Alright... i have a ton of shit for sale so if you dont see it, feel free to ask. this is probably half of the stuff i have lying around the garage. all prices are OBO unless firm is stated...
shipping and paypal fees apply. i also will not ship some items. All items are as-is. i dont sell shit i throw it away. nothing is broken. *mods* its just one item on ebay. lol and 20+ items here. I added my 38mm Tial wastegate on ebay for buy it now if anyone is interested aswell. No eBay links STI yellow 550cc injectors - $SOLD Emanage Blue, What you see is what you get. known working in a buddies car. comes wired into an s14 efi harness missing a plug or two $SOLD i have a download for the emanage software. and instructions on how to make your own com cable. Stock s14 shocks and springs. - SOLD n60 mafs purple lable. comes with pigtail - $60 Image 1 - S13 sr downpipe, no heat sheilds - $30 S13 5 speed driveshaft - $60 Stock s14 front swaybar and polyurethane D bushings - $20 Stock s13 rear swaybar - $10 S13 upper timing chain cover - $20 S14 Rear driveshaft from a NON ABS car. good carrier bearing - $20 Image 2 - S14 heater control valve - SOLD S14 SE rear trunk springs, stronger springs for wing trunk lid - $20 S13 valve cover, painted metallic charcoal grey, has gold colored flake for moar shiney - $40 stereo din cubbie thing - $20 s14 dead pedal - $20 s14 drivers window regulator, no motor - $20 stock gas cap... free if you need it!, but im not shipping it for free! Pull-a-part oil cooler, - $20 (3/8 fittings) would be good for a mild oil cooler setup... s13 high pressure power steering line / hose. $40 Image 3 S14 gauge cluster trim - $20 S14 fuse box cover - $SOLD s14 lower steerring wheel trim - $10 s14 kickpanel fuse box cover - $20 stock upper s14 airbox - $10 s14 glove box and bracket - $20 Image 4 Stock s14 rear muffler. good condition, has both tips and hangers. one hanger was bent and modified to lift the muffler a hair higher up. - $25 Image 5 two s14 climate control units... both work. $SOLD s14 dash to door vents *goes into dash* $20 solid urethane filled motor mounts. - $40 16 aftermarket lug nuts, with key - $20 S14 rubber ebrake handle trim *goes into center console* - $5 wiring nightmare of an oldschool viper keyless entry / alarm system ... $20.... worked fine in my s14 comes with remotes. windshield wiper handle - $15 light and blinker handle - SOLD image 6 s14 windshield wiper motor - $20 s13 windshield wiper motor - $15 S13 sr topmount T3 turbo manifold with t3t04 turbo. Turbo is used, and has mild shaft play, Unsure if its garrett or ebay. turbo is used. has garrett written all over it. ect ect. see pictures. Asking 300obo for the turbo and 150obo for the manifold. 400obo for both... manifold is some kind of custom made one, some surface rust. held pressure fine. turbo was used for a while. has typical black exhaust build up ect ect... 38mm Turbonetics deltagate used... decent condition a little surface rust $120obo SR bellhousing - $SOLD S13 speed sensor - $SOLD Pairs of 240sx axles - $50 a pair will not seperate. comes with axle nuts and washers These bins are full of stuff. i couldnt move them since my back is still hurting. so i snapped a few pictures. ill get my bro to help take more but they are filled with suspention parts and such. S14 base model front spindles and hubs, good wheel bearings - SOLD s13 stock rotors $10/pair s13 calipers front $40/pair s14 front calipers s14 rear calipers $50/pair front and rear rubber brake lines comes with calipers... or $5 /pair s13 front lower control arms ball joints have no play but need new boots - $20 both 5 speed transmisison backing plates - $25 each s14 a/c compressor $40 s13 ka24de alternator $40 Stock s14 rear traction $20/pair thers more stuff in there that i will add as i go... Last edited by viperbite; 07-19-2009 at 03:23 AM.. |
if you paypal me 20 dollars ill ship it wherever in the country you want.
i might also add they are both from 1995 model cars. if it makes a difference. both a/c units have a little bit of wear on the buttons from being pushed alot. and one units mounting points were filed down a hair to mount in a radio bezzle. it will still bolt into the stock location aswell though. send me a PM if you want it. |
i actually just sold the heater control valve locally
as far as shipping an axle... it would probably be close to 25 dollars to ship it ups ground... so by that point you might as well buy a remanufactured axle for just over 100... but i guess i can ship one if you want. |
