replaced headgasket, IT DIDNT SEAL ka24de s13
Hey i have a 92 ka24de hatch. all stock. The motor (head and block) have stamps on them indicating that they have been re manufactured or rebuilt sometime ago. I bought the car with a blown head gasket, the car started and idled and drove fine but puffed out thick thick thick white smoke as it warmed up. I took the head off, checked the old head gasket and it did not look to be noticeably blown anywhere, looked pretty good actually. I took the head to be resurfaced and pressured tested, when I got it back I installed it with a new felpro head gasket and head bolts. The car started no problem but it still puffs out white smoke like crazy!!! just like before.
I pulled the spark plugs to inspect and i found green coolant on spark plugs 1 and 4. 2 and 3 where dry and good. what should i do? the only problem i think caused this is, i had to reposition the head gasket after i torqued it down (it was torqued for 5 mins) because the timing cover bolts would not line up with the head gasket bolt holes, so i loosed it, reposition it a tad bit and re torqued it. would this cause the head gasket to not seal properly? |
![]() Join Date: Sep 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Head gaskets can't be reused normally, onced they are torqued the rye used. Did you torque it properly? You can proably take it off copper apart it and she'll seal.
yes, it was torqued properly in the sequence given in the fsm. would you think the block or head is not properly straight? Do I need to resurface the head again before i put the new head gasket now?
ah, good point there Chaluska, but why wouldnt it seal then?
Im pulling the motor out again soon. should i get anything checked while i have it out and apart again? |
Take your radiator cap off and crank the motor over. Pull the fuel pump fuse or unplug the distributor,look and see if coolant bubbles out of the radiator. Also have u looked at the intake gasket? Possible even a water jacket issue.
![]() Join Date: May 2008
you sure it wasn't a ton of water collected in the exhaust pipe steaming out with the exhaust?
i find it hard to believe that a brand new felpro gasket wouldn't fix the problem. did you do a compression test? cylinder leak down test?
#9 | |
![]() Join Date: Feb 2012
Trader Rating: (37)
The answer is, "no, you do not need to resurface the head".
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
![]() Join Date: Jul 2005
the fsm outlines a proceedure for checking the straightness of the head and deck prior to installation of a new headgasket. Did you do this?
Furthermore, how did you prep the surfaces? And also, did you follow FSM torque proceedure? Did you check the stretch of the OEM bolts? Nobody does... For $450~ You can find a complete KA24DE with 120,000-150,000 miles from a 95+ model 240sx and swap it in. Thats your best bet. |
#12 | |
because that answer is obvious... ![]()
#13 | |||||
![]() Join Date: Sep 2005
usually there is evidence on the oem type head gaskets the water or oil take when the gasket leaks. just examine it, you might see something there. You can also tell if it was the head side or the block side unless the fire ring pealed or blew out. g\l
when i pulled the head gasket the first time, i expected it to be shot but to my surprise there was nothing clearly wrong with it, it looked to be in great shape and not blown. Im expecting the same results with the felpro im about to pull out. Hopefully there is a clear signal that its leaking coolant around cylinders 1 and 4. ill post pictures this weekend when i got it out.
