![]() Join Date: Apr 2005
Looking to install my rods in my rb25 but i need the bearing clearances... anyone know or show me where to look it up ?
Factory service manual
MRP Manufacturing |
Around .002"
Well, bearing clearances are all really up to a few factors,
1) Engines intended use 2) Hardware used 3) Oil viscosity and assuming you're doing an OEM rebuild with oem hardware around 2 thou would be in the limit, and on the "tighter" side which is what you'd want in a daily driver. Rod bearing clearances are also always slightly smaller than mains in case you were wondering about those too. I want to say in my SR my rods are around 2.5 thou and my mains are closer to 3 thou |
Also a "standard" ACL bearing is not the same size as a standard OEM bearing, the ACL will be slightly tighter due to it being coated.
Sorry to keep bumping this, but I just wanted to back what I said with some tangible evidence. The bearing clearances we run on David Briggs SR20det are:
Rods .002x" Mains .002x" And this is fairly standard like I previously stated. |
Thanks for all the replies. The more the better.
Its intended to be a summer DD / weekend warrior Cp pistons/ Manley h beams with acl main and rod bearings |
Then shoot for .0017-.002" for your rods and right around .002" for your mains. We run these on engines we build for a shop that specializes in Skylines. Also make sure to check your rod and piston manufacturers torque and clearance specs as those don't follow oem rules.
Thanks for the tips! Appreciate it a bunch!
And i already checked the rods and pistons and they came with the information for the specs so im good there... its just these bearing clearances that confuse me but i think i got it now You think .003 clearance from plasti gauge measurement is ok for mains? |
That's on the "looser" end of the spectrum, that's what my SR mains are and that's an engine I'm planning to drive harder and hotter, hence needing the room for expansion.
Well it's not going to initiate any code red self destruction sequences, you're still in spec. Just run a thicker oil like 10w30 and do 3k oil changes and you'll be fine. The extra clearancee is a cushion for thermal expansion that occurs with harder driving.
#17 |
You guys need to specify what unit of measure you are using.. metric or standard. the factory manual is metric... Most people including myself refer to an Inchs measurement.
.0015-.002 inchs is right where i have mine... 500-800whp 9k RPM going on its 7th year. |
I've been giving measurements in standard hence the (")
| acl race bearing, clearance, rb25, rod bearing |
