Old 10-21-2008, 10:37 AM   #1
zilvialatorre
zilvialatorre's Avatar
zilvialatorre is an unknown quantity at this point
s13 diff- how much lsd oil required to change it? and what weight lsd oil use?
i want ot change my s13 lsd diff oil (5 bolt)
pls advice...
thanks
zilvialatorre is offline   Reply With Quote
Old 10-22-2008, 12:42 AM   #2
shortcake
shortcake is an unknown quantity at this point
First off you don't need LSD oil, but i would spend the money on Synthetic, i personally use Mobil 1 75w90 GL5 but any type of 80w90GL5 will work fine.
iirc you'd need 1.5L
the FSM says you'd need about 1.2L to 1.5L but for me i'd just buy 3 bottles just in case, you can always return the bottle afterwards.
hope that helps .
shortcake is offline   Reply With Quote
Old 10-22-2008, 05:03 AM   #3
zilvialatorre
thanks for the info.....i have an lsd diff..... so you mean i can use a synthetic oil on my diff. and its 1.5l...ok thanks man.....
Old 10-23-2008, 12:27 AM   #4
shortcake
you can use synthetic is you like, but only regular is required. But imo you should spring for the synthetic.
Old 10-23-2008, 10:41 AM   #5
dino6192
dino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond repute
depends on your diff. if you have a aftermarket KAAZ or Tomei, nismo...2way or 1.5 you definetly DONT want to use regular gear oil in there! you can find the required LSD oil on all kinds of sites including the manufacture.those types of LSD's oil usually come in big can container's. if you have a OEM diff. like a open or viscous you can just use the gear oil mentioned above (80w90 full synthetic). do you know what type of diff you have?
Tsuiso.Style @ Instagram
dino6192 is offline   Reply With Quote
Old 10-23-2008, 10:46 AM   #6
Somnambulist
Somnambulist's Avatar
Somnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfection
Send a message via AIM to Somnambulist
I use Royal Purple 75w90 in my J30 VLSD. I prefer it over Mobile 1 since it's not a true synthetic oil.
But personal preference is key.
Somnambulist is offline   Reply With Quote
