![]() Join Date: Jul 2007
Trader Rating: (106)
kouki s-14 5-speed swap CEL question
I am doing a 5-speed swap on a kouki s-14 and this is the first 5-speed swap I have done on an OBD2 car. I was told that if I don't wire the 4th and 5th gear switches up to the computer that it will throw a CEL. Is this true? If so are there any tricks to the wiring to avoid the CEL? I don't like half assing my work and I wanna make sure it is done 100000% right the first time. Any help would be appreciated, thanks.
It won't throw a CEL for 4th/5th gear switches.
It *will* throw a CEL for the neutral switch. The computer will look for the neutral switch to close and open at least once each driving cycle. A driving cycle means the time between engine on and engine off. When I first did my swap my harness had an open circuit to the neutral switch, so I wired up a toggle switch on that circuit and I just switch it on and off when I get going. Also, since this is your first OBD2, remember that you must remove the crankshaft position sensor before removing or installing the transmission. If you leave it in it is likely you will break it. |
#3 | |
I pulled the trans with the sensor in, no problems. When installing the 5-speed though I will have the sensor out as clearence is much tighter with the 5-speed. I didn't think that the 4th and 5th gear switches would throw a light, that is cruise control stuff. |
#4 | |
![]() Join Date: Dec 2002
You'll need to use a manual ECU as well otherwise the CEL will trip from missing automatic transmission inputs.
If you have a kouki, make SURE you have a kouki trans. If you dont you won't be able to put the crank sensor back and it will throw a CEL (duh). I HATE half-assing shit, but my customer didn't quite do all the right research and get the 100% right parts. I was too pre-occupied to do it for him.
#10 | |
I suspected that it was an 89-90 trans and this verifies my suspicion. Guess who sold the trans as an s-14 trans.... Otis with RBperformance, now known as Otis performance. BIG surprise huh?
SOHC transmissions won't have the 4th gear switch, so if it's only got three switches, VSS, and no CPS, it's a 89-90 unit.
