![]() Join Date: Jun 2010
i need to know the individual chamber sizes on a z32 BMC
I'm running z32 brakes on a custom project of mine and I'm going to be running floor mounter pedals and the braking system uses two non vacuum assisted master cylinders on for the front and one for the rear...
i know the z32's use either a 1" or 17/16th bore size, but is that the combined bore size? and since the brakes are not vacuum assisted i don't know if that will change MC size that i need? i need to know the front bore size. and the rear bore size. so i can buy the correct master cylinders. |
![]() Join Date: Sep 2006
Index of /FSM/300zx
click on year, then click on BR (brakes.) then press the 'end' key to shoot you down to the last page, look for 'general specifications' which is one of the last pages.
formerly known as "hotboiblaze" ![]() ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
i didnt tell you shit, nissan did. hahhaha
