Old 07-31-2012, 08:23 AM   #1
Flicktitty
Flicktitty's Avatar
Brake pedal to the floor (again)
So i did a Q45 brake swap on the S13 coupe over winter, Noticed it was leaking fluid from the caliper, So i replaced the caliper and didn't see any more leaks. Bleed the brakes pedal was good as new. then i noticed the reservoir was going down without using the brakes (just sitting in the garage) I I went back through didn't see any leaks so i assumed with the new Q45 stuff it might have killed the BMC. So i replaced that. bleed the brakes. pedal was fine. Went around the block car was good. parked it and then loaded it onto a trailer took it to get dynoed, now the pedal just goes to the floor.
Run down of parts-
Stainless steel lines.
1 Refurbished Q45 Caliper
1 Used Q45 Caliper
"cheap" temporary brake pads
Sentra SE-R EBC Rotors
DOT4 Brake Fluid
Refurbished BMC
So most of the parts have been replaced on the front, i'm still not seeing any leaks, I Suppose the used caliper could be bad, or maybe something with the rear? Any ideas?
Old 07-31-2012, 09:27 AM   #2
Sileighty_85
Sileighty_85's Avatar
Did you bench Bleed the MC?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-31-2012, 10:41 AM   #3
Flicktitty
Flicktitty's Avatar
Yessur i did, Did it till there was no visible air coming out then bleed all 4 brakes. Pedal was fine for a few weeks just sitting, then it went to the floor after a few times pressing it.
Old 07-31-2012, 03:22 PM   #4
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
got a leak somewhere.
rwtf is offline   Reply With Quote
Old 07-31-2012, 03:28 PM   #5
PureRush
PureRush is an unknown quantity at this point
Yeah you have a leak somewhere. Take off all the calipers and check for brake fluid and check the lines. If there's no visible leaks then it's an internal problem in your BMC
PureRush is offline   Reply With Quote
