![]() Join Date: Nov 2008
ok my car was working fine turned on good but all of a sudden it died like there was no power I turn on the key on the switch nothing not even the cluster lights when on like if i had no battery well i checked that it was fine can it be like a relay i change the ACC relay already still nothing i really need some help on this or can it be ECU ??
Check the 75amp fuse..
