![]() Join Date: Dec 2002
Yes. It's called a ruler.
![]() Join Date: Apr 2004
Fronts bolt right up. You will need the hardware though, the Z33 uses a 14mm hole in the spindle vs. 12mm for the Z32.
![]() Join Date: Apr 2008
So let me get this straight... the 26mm's and the 30mm's CAN or CAN NOT use the same pads?
Internet vendors lack of information made me wonder. |
Same pads, only difference is thickness of rotor. I'm running them now on my car.
-Retired |
They weigh less. The Z33 is a dual piston sliding caliper, made of iron. It's a really big, heavy version of an Schassis front caliper. Which means the sliding pins can seize up too.
#19 |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
#20 | |
Inactive Admin
![]() Join Date: Mar 2002
*Banned* |
