#6121 |
![]() Join Date: Jun 2010
The FSM shows that the standard rack is 3.1 turns lock to lock, HICAS 2.6. I imagine the benefit of the HICAS rack would be the smaller amount of input required for any sort steering, whether it be initial turn in, feint initiations or mid-corner corrections. I don't think there would be any improvement in counter-steering as the wheel moves faster than your hands can turn it.
#6122 | |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 2 reviews
#6123 | |
Sent from my SGH-T989 using Tapatalk 2 |
#6124 | |
![]() Join Date: Nov 2005
#6125 |
Would it be possible to compile a list for the first page of how each change to one of the front and rear suspension characteristics (ride height/camber/toe/caster/etc.) affects the others?
For example, adding negative camber in the rear adds toe-in and caster, and probably other stuff. I know there a lot of factors and it has all been said before, but it would be nice to have a general reference guide for the S-chassis suspension behaviour. |
#6126 |
Also, this one time, years ago, I pressed the ball joints into my FLCA's upside down, and I ran the tension rods and FLCA's upside down (on the opposite side of course), because I thought that the FLCA-to-knuckle angle would be easier on the ball joint on an over-lowered car where the arm points straight up.
[/embarrassingsecret] |
#6127 | |
![]() Join Date: Feb 2012
Sent from my SPH-L710 using Tapatalk
ACE マジック HEART |
#6128 | |
settings make the car handle. http://http://www.motoiq.com/Tech/Th...Handeling.aspx |
#6130 |
Make it double adjustable and ill paypal you the money right now.
Gee Spot Garage, doing things you don't. |
#6131 | |
Seriously, i want/need asap
#6132 | |
#6133 |
I am putting a threaded rack spacer on with 25mm extended S14 LCAs and 25mm roll center corrected cut spindles. I Have Tein Inner and Outer tie rods.
Should I run 2 Rack Spacers or Longer Inner rods? |
#6136 |
I want to extend my front lower control arms on my s14. I was thinking 25mm. all I have in front suspension wise is bc coilovers and hardrace castor rods. I heard all I will need to suit is Maxima tie rod ends. What year model is best to get?
#6141 |
Read one page back you lazy ****
#6145 |
![]() Join Date: Apr 2004
Just a minor nitpick, but the final "tear drop" cut out would be stronger if the metal remaining was more inline with the stresses going through the arm. Basically it should form a triangle and not a bent curve. (not saying it'll fail, just friendly advice)
#6146 | |
Best way to move the rack forward? Is there a "rack forwarding kit" readily available?
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
#6147 | |
Eccentric bushings. They are probably the closest you'll get without actually moving your rack forward. |
#6148 |
Has anyone received their gktech bolt-on roll center / bump steer / steering angle kit yet?
They are supposed to be arriving end of january.
#6149 | |
hope this helps
[email protected] |
#6150 |
Edit: Nevermind, thought we were talking about a different gktech piece
cONtRol FReAkS Last edited by conrad_s13.5; 02-04-2014 at 07:37 AM.. |
| anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
