Old 04-28-2012, 09:54 AM   #301
Kingtal0n
Kingtal0n's Avatar
Cookie cutter swap:
JDM 2JZ, Precision PT6776, roughly 800RWHP @ 32psi with OEM camshafts.
Old 04-28-2012, 11:37 AM   #302
1jzs14
1jzs14 is an unknown quantity at this point
Does water wetter really work that much?
1jzs14 is offline   Reply With Quote
Old 04-28-2012, 11:47 AM   #303
1jzs14
and will running without a hood cause my temps to be to high?
Old 04-28-2012, 12:06 PM   #304
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
water wetter actually does help, yes. don't run without a hood, that's dumb. it will probably be okay, but still look stupid.
SW Fab
shiftdrift is offline   Reply With Quote
Old 04-28-2012, 04:35 PM   #305
1jzs14
Well I don't have a intake yet so I just put a filter on the intake
Also does anyone have pics of yalls speedo Dakota boxes mines getting power but not letting out any speedo reading
Old 04-28-2012, 04:56 PM   #306
BadazzSr20
BadazzSr20's Avatar
BadazzSr20 is an unknown quantity at this point
so i got the car put together and i try to start the car but there's no spark i checked all the grounds and plugs but no luck. i dont think the harness is getting power anyone have a idea how to get power to the harness?
also the fuel pump isn't working and my turn singles don`t working? i talked to the guy about my fuel pump is said what the pump wont prime it will work when the car is started. but with no power to the harness im stuck now??
BadazzSr20 is offline   Reply With Quote
Old 04-29-2012, 06:41 AM   #307
1jzs14
do you have the body harness connector connected? and also theres a whole bunch of grounds on the pass side check those
Old 04-29-2012, 11:13 AM   #308
BadazzSr20
BadazzSr20's Avatar
every plug on the harness is pluged in and grounded. i have a s14 and im starting to wonder if the harness is missing plugs. by looking at the pictures of the black kouki i already see a plug that i dont have on the top of the fuse box that gray one. also i think he has the other 2 under that pluged in aswell.
i dont have none of them plugs on my harness. if someone can please post some better shots of that fuse box so i can see the 3 plugs that runs along the side of it. also some shots of the ignitor and the plugs there please.
i have the same car as that black kouki if you can post some pictures of what i need please being u got the same car as me it should be the same setup as far as the harness goes.
thanks
Old 04-29-2012, 03:24 PM   #309
1jzs14
I have a Zenki but I'll post up pics tonight when I get home
Old 04-29-2012, 09:36 PM   #310
BadazzSr20
BadazzSr20's Avatar
thanks man that would help alot
Old 04-30-2012, 12:14 AM   #311
jamg
jamg is an unknown quantity at this point
did some researching on swapping a 1jz into an s13, it's looking bleak. price wise, cost, difficulty- i'm better putting in an SR instead.
jamg is offline   Reply With Quote
Old 05-03-2012, 12:35 AM   #312
calebbo
calebbo is an unknown quantity at this point
This is some serious business right here guys haha and I plan on jumping on the bandwagon. In Mississippi they don't have to much of this going on so I don't have much help like I did when I was in Houston. So here is the list I have so far. Please tell me if I need anything, I just want to swap a 2JZGTE in my S13 so I can use it as a bad arse daily driver LOL.
2JZGTE MOTOR
(ZEROLIFT) $2,500.00
R154 TRANSMISSION
(QUALITY USED TRANS) $1,000.00
MOTOR/TRANSMISSION MOUNTS
(EBAY) $160.00
ALUMINUM DRIVESHAFT
(SHAFT MASTERS) $378.00
GODSPEED RADIATOR
(EBAY) $190.00
MISHIMOTO G LINE INTERCOOLER
(AMAZON) $168.00
EXTENDED SHIFTER KIT WHERE DO I GET THIS AT?
$300.00
FRONT MAIN SEAL
(DRIFT MOTION) $12.85
REAR MAIN SEAL
(DRIFT MOTION) $32.00
IGNITER
(DRIFT MOTION) $150.00
OIL PUMP
(DRIFT MOTION) $185.00
SERPENTINE BELT TENSIONER
(DRIFT MOTION) $132.00
SERPENTINE BELT
(DRIFT MOTION) $25
THERMOSTAT
(DRIFT MOTION) $21.00
TIMING BELT
COMPLETE GASKET SET
(DRIFT MOTION) $439.00
1JZ FLYWHEEL
(DRIFT MOTION) $275.00
STAGE 2 CLUTCH KIT
(DRIFT MOTION) $425.00
TOYOTA OIL FILTER
(DRIFT MOTION) $6.00
WALBRO FUEL PUMP
(DRIFT MOTION) $115
FULL LENGTH CLUTCH HOSE
(DRIFT MOTION)
[USE WITH S14 OEM MASTER SLAVE CYLINDER] $45.00
ENGINE/TRANSMISSION HARNESS WIRING
(FREEDENGINEERING) $500.00
Questions:
- So I need a flywheel for a 1jz and a clutch kit for a 1jz OR 2jz?
- Are the clutch lines and fuel lines confusing?
I have been researching this the past week and still have questions so please bear with me. If you found anything in my list to not be MANDATORY AND 100% NEEDED to keep my engine reliable then please tell me or if you know of a cheaper product that will put out just as much I'm always open for cheaper alternatives LOL
calebbo is offline   Reply With Quote
Old 05-03-2012, 04:20 AM   #313
bullfrogg0
bullfrogg0's Avatar
bullfrogg0 is an unknown quantity at this point
You gotta remember the 2jzgte was offered in the states as the turbo mkiv supra so parts can be had from your local parts store as well. The timing belt, best bang for the buck, is the gates racing timing belt. mine was a whopping $35 shipped
bullfrogg0 is offline   Reply With Quote
Old 05-03-2012, 07:22 AM   #314
1jzs14
2JZGTE MOTOR
R154 TRANSMISSION
(EBAY) $160.00
ALUMINUM DRIVESHAFT
GODSPEED RADIATOR
(EBAY) $190.00
(AMAZON) $168.00
$300.00
FRONT MAIN SEAL
REAR MAIN SEAL
IGNITER
OIL PUMP
SERPENTINE BELT
(DRIFT MOTION) $25
THERMOSTAT
TIMING BELT
COMPLETE GASKET SET
1JZ FLYWHEEL
STAGE 2 CLUTCH KIT
TOYOTA OIL FILTER
WALBRO FUEL PUMP
(DRIFT MOTION) $115
(DRIFT MOTION)
Questions:
for clutch you use a r154 one cause thats what trans you have
Old 05-03-2012, 07:30 AM   #315
HiI'mDustin
HiI'mDustin is an unknown quantity at this point
Add getting a daily driver into that build as well....If u dont have all the brakes and suspension add another 3-5k
to do this right its not a cheap build and I havent seen anyone do a GTE swap under 10k....People have spoken about it but no one has come out and said they have done it....
HiI'mDustin is offline   Reply With Quote
Old 05-03-2012, 07:32 AM   #316
HiI'mDustin
And you can find an R154 for $500 just keep looking around...1k is way too much imo
Old 05-03-2012, 09:45 AM   #317
Kingtal0n
Kingtal0n's Avatar
There have been a few questions regarding the radiator and core support:
We (Specifically, "Larry" at Team orange inc, previously known as Drag International) have done about twenty of these swaps to date; none overheat, none have problems. Its a "cookie cutter" deal these days, we cut a good 1.5" out of the core support and relocate the condenser, sometimes using a condenser from another vehicle (a civic condenser fits well!) and that gives plenty of room for slim-line flex-a-lite fans, which are always individually wired via twin relays capable of supporting the constant current demands. Yes we maintain the A/C!
Take your time and cut carefully, straight and clean, make a nice bracket and aluminum cover, it will be functional and pretty.
Heres another one:
Old 05-03-2012, 11:25 AM   #318
2muchboost
Trader Rating: (33)
Feedback Score: 33 reviews
Thank you sir for that information. I had seen some of your older cars but had not seen anyone from Drag Int. post recently. I have that exact same setup for the radiator and fans....glad I made the right choice.
Old 05-03-2012, 05:32 PM   #319
calebbo
So 1JZ bell housing
1JZ flywheel
R154 clutch
And the reason I priced a R154 is because it's hard to find around these parts. Like I mean RARE.
Thanks guys!
Old 05-03-2012, 11:07 PM   #320
waste_of_space
waste_of_space is an unknown quantity at this point
Your motor set should come with ignitor/electronics and what not already.
I'd say stay away from a knock off rad, as people tend to have cooling problems with lower quality radiators. Also you'll need a front sump oil pan setup, and sway bar spacers, and if you get a jdm engine (like an aristo 2jz) you'll need to swap the stock hydrofan water pump setup for a mechanical water pump (such as the na supra mkiv pump). And as others have stated get belts/other oem parts from the Toyota dealer to save yourself some money.
Clutch line go to oreilly's and have them make you one after you take measurements. If you're not going to run ac you'll need to get an audi serp belt (a4, iirc). You dont really need to get a full gasket set, just get the usual (cam/crank seals, front/rear mains, and valve cover gaskets)
waste_of_space is offline   Reply With Quote
Old 05-07-2012, 04:46 PM   #321
1jzs14
ok so i drove my car to town for the first time today it got up to 210f today is that bad in these if so what do i need also i tried to find a lower thermostat for but i couldnt find anything tried water + water wetter no luck of bringing the temp down does anyone one know where i can find a lower temp thermo
Old 05-07-2012, 05:24 PM   #322
bullfrogg0
bullfrogg0's Avatar
U can buy either a trd thermostat (160*) or a mishimoto 140*. What radiator/fan combo are u using? In the heat today and in traffic mine never got above 180. My setup is koyo tad, generic 12" fan and trd thermostat.
Old 05-07-2012, 10:27 PM   #323
Deftec
Deftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-known
Squeezed another 25hp out of it today on 28psi/c16. Time to go to a bigger turbo lol.
Sorry about the sweet quality. Apparently I suck at recording on an Iphone.
2jz 240sx dyno - YouTube
http://i98.photobucket.com/albums/l258/Deftec/signew-1.jpg
Deftec is offline   Reply With Quote
Old 05-08-2012, 03:47 AM   #324
jdm2191
jdm2191's Avatar
Trader Rating: (79)
jdm2191 is an unknown quantity at this point
Feedback Score: 79 reviews
2JZGTE MOTOR
R154 TRANSMISSION
(EBAY) $160.00
ALUMINUM DRIVESHAFT
GODSPEED RADIATOR
(EBAY) $190.00
(AMAZON) $168.00
$300.00
FRONT MAIN SEAL
REAR MAIN SEAL
IGNITER
OIL PUMP
SERPENTINE BELT
(DRIFT MOTION) $25
THERMOSTAT
TIMING BELT
COMPLETE GASKET SET
1JZ FLYWHEEL
STAGE 2 CLUTCH KIT
TOYOTA OIL FILTER
WALBRO FUEL PUMP
(DRIFT MOTION) $115
(DRIFT MOTION)
Questions:
Well on the R154 you can probably go the easy route if your patient & find one for like $400 on Craigslist, but you'll still need a 1JZ Bellhousing & Shifter Extension but on those 2 items you can get some really good deals on Supramania like I did or hit up Aaron at Driftmotion & he can make you a shifter extension, Aaron is a LEGIT ASS DUDE! Or if your a baller just get a Soarer R154 & its PNP
If you get a Engine set for $2500 im pretty sure you'll get a Ignitor, & if you get a Gasket set you'll get all the main seals btw
When it comes down to PS, Clutch & Fuel Line just get them from Chase Bay they make them for S13 to 1JZ/2JZ with no hassle on your part or can make your own with Earls, XRP or other aftermarket AN Hose & Fittings
& I recommend getting a OEM MK4 TT Fuel Pump, best bang for the buck!
With the flywheel/clutch situation just make sure you get a R154 Flywheel & any 7M-GTE/1JZ-GTE/2JZ-GTE to R154 will work you can go with 7M clutch kits to save money because most 1JZ/2JZ R154 are Expensive
My Build: The "Coupe De Ville" 1JZ Build!!
jdm2191 is offline   Reply With Quote
Old 05-09-2012, 04:40 PM   #325
1jzs14
i put the mishi one in due to the heat mishi radiator dual 12' fans but that thermostat brought it down to 160 cruising we will see once i start putting it through its paces
Old 05-10-2012, 10:50 AM   #326
Mr. Phonso
Mr. Phonso is an unknown quantity at this point
Hey I have a couple of questions that I could not find the answers to. So why not ask in a thread where people have actually done the swap, to add to the great information already here.
This is all regarding s14 chasis with Aristo 2JZ
1. Anyone have any experience using these ebay mount brackets? 240SX S13 S14 SWAP ENGINE MOTOR MOUNTS BRACKETS 1JZ 2JZ | eBay
2. When fitting the r154 does it fit properly in the transmission tunnel?
3. If ever doing a clutch job in the future would there be enough space to drop the transmission alone?
3. If anyone has experience with the above mount brackets, and has a soarer r154 does the shifter line up proper?
4. Is it possible to get the r154 to feel as short and as precise as the sr/ka with short shifters? All my friends cars with this transmission has some sort of shifter play.
That is all the questions I have, if anyone could answer them I would appreciate it very much.
Mr. Phonso is offline   Reply With Quote
Old 05-10-2012, 01:26 PM   #327
jdm2191
jdm2191's Avatar
Trader Rating: (79)
EDIT 4. If anyone has experience with the above mount brackets, and has a soarer r154 does the shifter line up proper?
5. Is it possible to get the r154 to feel as short and as precise as the sr/ka with short shifters? All my friends cars with this transmission has some sort of shifter play.
Im doing a 1JZ S13 Swap, but to chime in from my knowledge
1. I have a "Tech 2" kit so idk about that?
2. Yes, should fit properly
3 That idk, i rather just pull the whole engine out as one much easier
4. Yes with a Soarer R154 you shouldnt have no problems with any mount kit, its the Supra R154 you need to worry about Extending
5. & yes buy Marlin Crawler Shifter sockets & you will have a nice new shifter feel , with no play
Old 05-10-2012, 04:11 PM   #328
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Someone take this off my hands!
#/f/sale-items/45272...ml#post4684435
Old 05-10-2012, 08:57 PM   #329
Mr. Phonso
Thank you very much jdm2191. So if I am to understand correctly our cars don't need transmission tunnel bashing to fit an r154?
Still would like if someone can comment on the mount brackets if they have experience with using them
Edit: Also I am told that the Marlin Crawler Shifter sockets do not work for the soarer transmission setup. Is this true?
Old 05-11-2012, 12:07 PM   #330
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Yeah I never heard that Tunnel bashing is required unless maybe you have a Getrag
& About Marlin Crawler situation look it up at Driftmotion.com
