![]() Join Date: Sep 2013
Ka24de dies when throttle applied
I have a 93 dual cam that I just put used injectors in and it starts and runs, but when I give it gas it will die, video shows. Basically are the injectors junk or what's my problem?
Any and all help is appreciated, thanks Sent from my iPhone using Tapatalk |
Why did you install the new injectors? and have you tried any diagnostics on your own?
First place i would start is unplugging the maf and trying to run it. See if there are any changes. of course it will cut at 2.5k, but see how it revs up to there. |
It had a Ka-t in it and he left the sr injectors in the car, so I needed to get stock ones, and I did get a new maf and wired it in, I will try to unplug it in a few mins and report back
ImageUploadedByTapatalk1409869204.933997.jpg ImageUploadedByTapatalk1409869246.176596.jpg Found this too Sent from my iPhone using Tapatalk |
get thise connections cleaned just in case, and what number is the ecu? it will be like E5 or 62 something along those lines.
EDIT: i dont see anything out of the ordinary, but maybe someone els will? |
Sorry man I'm in class right now, so can't really look into it, but I will later on today if I remember
#21 |
![]() Join Date: Apr 2011
Basics man. You need compression, air, fuel, and spark... Easiest are compression and spark. On an N/A you pretty much just assume you get air... So, with that...
Compression test engine. And either lay a wire on the head for spark. Or pull a plug and wire and look at it while cranking. Do this for each cylinder to verify spark. As far as compression testing: warm up engine to ~120, pull all plugs, pull fuel pump fuse, and crank while throttle plate wide open. Report back after these findings. |
#22 |
Were the "used" injectors flow tested? How did the seals looks on them? Seems as if the only real problem could be the injectors IF it was running fine before that.
Lexus V8 Into S13 Build |
#27 |
Got a new fuel pump and the same issue. Dies when you push in the throttle. So idk. Once and awhile the check engine light turns on and then off right away. Kinda weird. And now my battery is probably shot so I'm going to buy a new one to rule that out too.
