Oil Pressure Unit leak? Easy way to get to?
Hi,
I just removed my intake manifold and replaced ALL coolant hoses due to small leaks here and there on my SR20. I got everything back together changed the oil and cranked it up to make sure everything is good..
Now there is a nice stream of oil leaking from, it looks like,the sending unit next to the oil filter. The oil filter itself is dry and new. Is there an easy way to get to this without having to remove the whole intake manifold again?
I was thinking: remove the alternator and oll filter but i didnt want to waste time doing this if it didnt give me enough access to see why its leaking..
Thanks..
