#31 | |
![]() Join Date: Jun 2005
#33 |
![]() Join Date: Aug 2003
That is, if it doesn't cause you clearance issues with that 0 offset of yours
Petition Nissan to Make the IDx on http://IDxClub.co ! |
#35 |
AFC #1
![]() Join Date: Oct 2003
It helps when changing directions. Some flex allows the tires to stay in contact with the roads during sudden direction changes.
You don't want so much flex that the tire rolls over onto the sidewall. This has more to do with sidewall construction than height. I had a write up somewhere. I'll search for it. Also the wider tires will last longer.
#37 |
![]() Join Date: Sep 2004
the 205's i just got for my new 16x7's look pretty damn fat to me. for less than legit racing conditions or under 250whp i dont think id go wider than 215 even if i could. I think i can grip like nuts as it is with my coilovers and 195/60/15 Bridgestone RE92's on 5.5" wide rims. remember gas mileage is slightly affected by how much road contact there is as well.
#38 |
also, with sidewall flex, you get a sense of 'warning squeel', which you lose with stretched tires. Stretched tires tend to break with less warning
#39 |
![]() Join Date: Jan 2004
These pieces are going to wear out anyway, you can always try 205's, 215's, or 225's the next time around. Just do not get set into one thing being the say all be all for everything. Play around with it all. Get a good alignment too!!!!
I'm from Florida so I'm probably a bit more strange than you |
