Old 05-04-2008, 02:22 PM   #1
a100pureplayaz
a100pureplayaz is making a name for him/her selfa100pureplayaz is making a name for him/her self
sr front cover removal
ok im puttin a new chain and guides in lower oil pan is dropped is there any way i can remove the front cover without removing the upper oil pan ?
a100pureplayaz is offline   Reply With Quote
Old 05-04-2008, 04:01 PM   #2
Sileighty_85
Sileighty_85's Avatar
nope you have to remove the upper pan also, cuz the oil pumps pick up will hang up on the upper pan
you can see part of the the pumps pick up hang below the oil pump cover and in to the upper pans area So it either the upper pan or the head, but dont forget about the two bolts inside the valve cover that bolts the head to the oil pump
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-06-2008, 08:32 PM   #3
a100pureplayaz
thanks so much wound up pulling the motor out lol guess wasnt left with much of a choice since i dropped the chain what rear main seal matches the sr's? the ka or sr's?
Old 05-06-2008, 08:35 PM   #4
a100pureplayaz
also i have a t25 but recentley got a t28 we have the bracket/adapter but can i reuse the stock lines or need new ones?
Old 05-06-2008, 08:54 PM   #5
blownmotor
blownmotor's Avatar
blownmotor is on the path to ruinblownmotor is on the path to ruin
USDM rear mains work b13/14 sentra se-r's or infiniti g20's all years as for the turbo lines you can but you have to carefully bend them or easier and just buy new braided ones
blownmotor is offline   Reply With Quote
Old 05-06-2008, 08:58 PM   #6
a100pureplayaz
1991 sentra se-r seal will work correct?
Old 05-06-2008, 09:05 PM   #7
blownmotor
blownmotor's Avatar
yes buy oe, others will leak
Old 05-06-2008, 09:11 PM   #8
a100pureplayaz
lol work for nissan def will thanks so much the rear tailshaft seal is off a ka though correct?
Old 05-06-2008, 09:13 PM   #9
blownmotor
blownmotor's Avatar
yea it's the same
