JZ to 350z collins stage 3 kit (black non cut adapter plate)
2k miles on the entire set up. Going twin disk
2jz/1jz adapter plate with hardware Collins single disk 350z flywheel with hardware Collins adapter pilot bearing Spec stage 3 6 puck Collins extended throwout bearing Cast throwout fork with the necessary size pivot ball $1200 Will sending pictures via txt
'97 S14 KOUKI |
