sohc tach signal?
I have a nx1600 gauge cluster and the sohc signal doesn't give the same signal as a dohc. So i tried just hooking up the tach wire from the cluster to the green/black wire fom the ignition coil and still nothing. Is there anyway to make the sohc tach signal the same as a dohc tach signal
