![]() Join Date: Jul 2011
Clutch or transmission
I have search google and nothing. I'm having issues with my clutch or tranny on a CA18. It's been happening often, when I'm crusing to a stop on any gear and I'm close to coming to a complete stop and press in the clutch to put it in neutral. The shifter sometimes does not want to come out of gear I have to force it out of gear or give it a quick little rev on the gas to disengage it out of gear. Also when it gets stuck in gear it gives the appearance of wanting to stall for a brief second. I'm wondering if it has anything to do with the throw out bearing. Any input will be appreciated
Sent from my iPad using Tapatalk |
![]() Join Date: Feb 2009
Sounds more like a clutch problem or something along those lines. Only way to really pin point it would be to drop the tranny. But when you rev it and it comes out easier is telling me the tranny is fine.
#9 | |
![]() Join Date: Oct 2011
![]() Feedback Score: 15 reviews
My friends mustang does the same thing. Your clutch is not fully disengaging. It could be the pressure plate, throw out bearing, or something in the hydraulic system. Before you take the tranny out, see if you can adjust your pedal
#12 | |
I'm sure a lot of people who are reading this post might be saying " why doesn't this guy just take the tranny out and check the clutch and get it over with" but being that its my daily driver I just don't have time to take it apart and do a detail check up and then put it back together while I order the part and then take it down again and put it back together. Just trying to save some time. Sent from my iPad using Tapatalk |
![]() Join Date: Sep 2007
Trader Rating: (32)
![]() Feedback Score: 32 reviews
you're not checking the tightness of the pedal, your adjustment will be the stroke of the clutch pedal rod (length), you can thread the rod in and out of the back of your pedal, effectively changing your clutch engagement, if its adjusted wrong it might not be disengaging all the way..
Thats what my first impression was. But he's not getting good engagement. The pedal could still be adjusted wrong, there could be air in the system, bad master or slave, bad throwout bearing, or clutch is shot. Try to adjust the pedal first. If that doesn't help and you already checked master and slave, well it's time to drop the tranny.
#15 | ||
Thanks guys. I will try adjusting the pedal tomorrow. Hope is just that Sent from my iPad using Tapatalk |
Man w/ CTSV & a Car Seat
Adjust the pedal engagement to the middle and are still running the stupid clutch damper loop? If you are, google search how to get rid of it and take it out. Makes bleeding the damn clutch line alot easier.
#17 |
Ok I adjusted the pedal but its too high now. Lol ill get home later and adjusted again. Yeah I'm still running the clutch damper. I'm afraid to break the hard line while twisting it
