s14 power window promb.
hey zilvia need help with my power window prom. Some reason the window doesn't go up. How do you know if your power window amp is bad. Casue only my driver side window doesn't wpork, and all ihear is clicking sound. Please help thanks
yep just driverside
i been searching and it says window amp also 1995 ONLY (out of all s14's) have window amp 96+ has window amp built in the switch is yours a 1995? mine is |
Rock wha U jock and don't talk if U ain't got!!
![]() Join Date: Dec 2002
I got lucky and snagged one off ebay for 35 bucks.
And yes that part is your problem. 100%
Don't mess with my monkey...he's loaded. |
#10 | |
In about 10-12 years it'll prolly go bad again....just replace. done.
#13 | |
![]() Join Date: Sep 2006
![]() ![]() Feedback Score: 2 reviews
http://www.nicoclub.com/articles.php?id=245266 |
... well since most of that info was useless, I'll go ahead and post.
Unplug the window motor. Wire it directly to the battery with some lone wire. 1 to pos, 1 to neg.. to power the motor directly, and reverse. the wires you're plugging into the motor connector. If the motor is fine, borrow a buddies amp and window switches.. I replaced my amp, and bam it stopped working again.. turned out the window switches were fucked up. So before you go replacing shit.. make sure it will actually fix the problem first. If I find the amp I had (1 week old), you can have it. -Bart |
If you've got a clicking noise and no worky for the window, it's 99.999999999999999% of the time the window amp.
There's always going to be exceptions to the rules....but I like my odds. Oh and DJ Sunrise, you may want to keep that amp. The second you get rid of it.....well you know.
right now im gonna try fixing /determining the problem
hopefully its just the amp update- i went out and the window started working on its own again? gonna try it again tonight Last edited by importdude; 07-18-2008 at 05:13 PM.. |
#20 |
Did you check your motor before you go any further? My amp is gone, but the motor was done also. The wire got caught at the gear, which overdrive the amp and burned the motor in my case. Now when I plug a new motor in, it will run for 2 secs then die again.
#21 |
![]() Join Date: Feb 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
well if youre not too anal about things then mostly all nissans and infinitys use the same amp/connector. the only differance is the mounting points.
i used my friends 14 for a day and just my luck as soon as i roll down the window i had the same problem so i used my m30s one first. when i had a chance i swapped it out with an s13 one and still works fine to this day. only other problem he had was his drivers side switches went out a couple months later. usually thats the problem with 96s though (i think the amp is built in to the switch). m30 guys had the same problem and said they used j30 and maxima amps so im pretty sure most of the amps are the same. just gotta ziptie it up or make a custom bracket if you need it mounted that badly. that should save you some money so you dont have to go out and buy a brand new one. |
#22 | |
#24 |
gawd i just got the same problem in my s14, driver side.. but i guess i will give that repairing thing a try, if not then ill just buy my self a new one:/
IG: @ozc2jz |
#25 |
well here it goes
today it wont roll up did all the stupid fsm stuff cant figure it out so i had to park in my cousins garage for the night early tomarro i will have to goto the junkyard to get a new amp to see if that fixes it, and then go look at my used door i bought hopefully it has the regulator on it so i can swap if it is indeed bad oh i cant repair mine b/c i cant see any solder points that are broken |
#26 | |
Or you can try to 'repair' the amp, I have no idea how to do this because I've never tried it. Mainly because you can find used amps for 40 online, or new for 75. If you don't have the cash for it, just leave it up and don't go through any drive-thrus for a while. Good luck.
#27 | |
i even gave the regulator power directly and it wont move ![]() going right now to get an amp |
#28 |
got a amp off a g20 today,
same thing my cousin opened the window motor and found out the "black voltage regulator" was the problem we made a little wire jumper and bypassed it, then it WORKED! so i just used it to reinstall window up now to find a new motor or that little chip |
#30 |
Part numbers are different because the bracket is different.
