![]() Join Date: Jan 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Need to finish selling of the rest of my S-chassis stuff so I can get to ordering parts for my ls G35 project.
All parts are in good working condition, parted out the car. Garrett GT2871R .64 exhaust housing HKS actuator. Comes with megan manifold and SS water/Oil lines (will not separate) less than 30 hours SOLD Aem Series 2 Standalone Wiring specialities harness (needs to be cleaned up but is complete for s13 and s13 SR) Includes GM 3 bar map (no more MAF sensor) AEM AIT sensor SOLD ID1000cc injectors $350 OBX Fuel Rail and hardware as well as appropriate AN Fittings for S13 With Sr $80 Intake mani sans fuel rail $50 Sr20det trans with Isis short throw, shifts great $200 Apexi N1 exhaust and matching 3 Inch downpipe with O2 bung $150 ISIS REAR coilovers. $200 SOLD Rear subframe minus arms diff and axles, comes with 4 lug hubs rotors, brakes and LCA's $75 Welded diff $75 Axles $50 for the pair Carbonetics twin disk clutch. No slipping worked great when pulled from car. Very smooth twin disk $800 Has regular plate (20% more clamping force) http://www.evolutionm.net/forums/evo...e-rebuild.html (if you're weary about buying a used clutch) Measured the discs yesterday for a potential buyer. Measured out at 3.97mm and 3.89mm Price new- http://www.brewedmotorsports.com/sit...N23230-14.html I have more pictures of discs and flywheels upon request for potential buyers. Turbosmart BOV $150 will include pipe with flange for V-band 1jz NON- VVTI full swap including extended wiring harness. $1500 VQ35de wiring harness ecu etc and cd009 6 speed trans $1500 still in the car, you can hear it run and drive it. All prices are OBO. I can ship everything listed at buyers expense. Pay Pal fee's are also the buyers responsibility. Would prefer not to ship the trans or subframe as the cost would be very high. Call or text for faster response 407-923-3211 Located in Orlando florida. Carbonetics Twin Disk Circuit Sports Coolant overflow s13 2X Rb25det ECU's SR20DET Coil Packs. 2 sets $50 each. $30 for harness. Isis Short Throw Shifter $50 SR20det Starter X2 $80 each SR20DET Alternator $80 ID 1000CC Injectors $350 1JZ Full Swap. Extended harness ecu etc. $1500 Silvia Grill $50 No broken Tabs Welded Diff $75 Axles $50 for the pair Bare subframe with LCA's and Hubs $75 Apexi N1 Exhaust Toda Cam gears S13 SR20DET Key way needs repair $50 2X Sr Transmissions $175 each SR20DET Ignitor Chip $35 Stock Sr Manifold with IACV $50 OBX Fuel Rail and adapters with AN Fittings VQ35de Full swap 190k miles. Motor 6 speed trans wiring harness ecu. Running and driving. You can come test drive it before I pull it out. $1500
#13 | |
Measured the discs yesterday for a potential buyer. Measured out at 3.97mm and 3.89mm. Have more pics of internals upon request.
#17 |
Yes, that's for everything you need. Already wired up and everything. Thanks! Everything is in great condition. I'm just trying to get the funds up before I start dumping money in my new project so this stuff needs to go. Hence the more than fair pricing on stuff.
