480whp sr20det part out!! APEXI/CUSCO/HKS/GREDDY AND MORE
BUILT 480WHP SR20DET PART OUT
All prices OBO and may trade for some 2jzget parts(TH400 swap parts, s14 suspension parts, ETC.) Mazworx Sr to Chevy Adapter plate and flywheel $400.00 JGY 72lb(750cc) injectors SOLD Apexi Power FC w/ controller SOLD Cusco 6 point roll cage s13 non sunroof(never mounted) $600.00 15” 4x4.113 Wheels almost new tires $150.00 Greddy RSPL FMIC $300.00 Koyo Radiator s13 sr20 w/ fan and hoses(needs polishing) SOLD Apexi GT Spec S13 exhaust w/ down pipe and test pipe SOLD Stock Coil packs with harness $40.00 Splitfire Coils with harness SOLD!! B&M short shifter $125.00 Greddy catch can SOLD Z32 MAF sensor SOLD Greddy manifold w/ throttle body (needs cleaning) SOLD JGY fuel fail/nismo FPR/ jgy 96lb(1000cc) injectors SOLD 1 piece driveshaft SOLD Gt2871r .81AR w/ss lines and exhaust manifold SOLD!!! Megan Dump Pipe SOLD ACT 6 puck unsprung clutch $100.00 could use new disc ACT 10.5lb prolite flywheel SOLD HKS step 2 cams 272 SOLD!! Greddy Rocker Arm Stoppers SOLD Ported and Polished/ 3 angle valve job HEAD, ARP head bolts. SOLD Built Bottom End short block, 86.5mm 8:5:1 Cp pistons, Eagle rods, crank was new, cleveite bearings SOLD Redtop Valve cover w/ spark plug cover $70.00 Sr20 transmission $175.00 call or text johnny 803-747-six,six,four,six Last edited by 1fastsil80; 01-10-2014 at 07:01 PM.. Reason: changed header |
#4 | |
Its is a redtop and im looking for something a little bigger then the gt35. lmk if you want anything, Ive got a lot of pm's on stuff already. |
Quality parts, good tuner, and 110 octane does miracles.
