#2011 |
![]() Join Date: Nov 2003
Im really more concerned with reliability, and beatability that I am horsepower numbers. I want the car to make good power, but at a safe level, and be able to beat the shit out of it.
-Kyle |
#2012 |
![]() Join Date: Jan 2003
![]() ![]() Feedback Score: 13 reviews
Sounds like a real enthusiast to me haha! I say who cares about peak this or that, how reliable is the tune going to be so you can beat on it and not have to worry about the engine holding up? Save for a few instances, I think their tunes are conservative enough to protect the engine, but still make great power. Keep us posted on which route you go.
#2013 |
OK but I have a question about a rom tuned ecu. I have one (Enthalpy), and would like a retune, but REALLY don't want to have to take it out and send it back for that. I like driving the car. What options do I have then? Can they send a chip with the retune i can swap? Or are the chips in the daughterboard using some sort of software that local tuners can use to tune and burn me a new one? I'm lucky enough to have several very good tuners nearby.
#2014 | |
![]() Join Date: Sep 2005
![]() ![]() ![]() Feedback Score: 7 reviews
#2016 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
Proper logging and gauges are the key to success; get a wideband, get nissan data scan (or similar) and goto town. You're not going to get much safer than a Rom tune.
#2017 | |
I have a wideband, and a boost guage. Thats all I will probably use if I go ROM tune.
-Kyle |
#2018 | |
edit: what else i dont get is how you have been a member here since 2003 and dont know most of these answers or how to search for these answers....hell even go back through this thread and all your questions are answered. (i can understand wanting to hear it really easily from these guys on here, but still its all been answered before by all of them) also if you want to look for reliability and beatability i would just stick with a t25, i will be the first to say i have beat the shit out of my car everytime i drive it (my boost controller never leaves 20lbs) and even still things go wrong...yes the tune and everything is spot on (JWT) but other things do break (clutches for example) that is just something to keep in the back of your mind |
#2019 |
I would, but my motor came stock with a T28, and I want more than 260HP.
Thanks for your input though man. I just like to hear the most updated research on these things!
-Kyle |
#2020 | |
your def in the right thread to get the most updated info i have the same set up as cody (he even built it haha) and can say nothing but great things about everything with the setup (turbo,JWT, cams, etc). the setup works, just trust it, and what they say |
#2021 |
![]() Join Date: Jan 2011
Trader Rating: (26)
I installed my 2871 .64 a few weeks ago. Love it but can't use it. At 7psi my stock injectors are at 100% Haha go me....
IG/TikTok-ThatS14_Z06guy
#2022 | |
![]() Join Date: Mar 2006
at least getting it to be "useable" is not far away.....injector swap and fuel pump swap are both really easy to do.
![]() Daily driven |
#2023 |
Trader Rating: (26)
I already have a fpr and pump installed. My plan is to throw on an isis intake mani and sti injectors a few days before my tune. Which isn't until the 15th next month by Steve Shadows.
18psi here I come. Weeeeeeeeeeeeeee
#2025 |
Trader Rating: (58)
With Steve it's probably Haltech
#2027 |
i just got back from the dyno dynamic's (heart break dyno) in ohio and made 338.00whp 19.1 psi on the garrett internal wastegate, if i'm guessing right thats around 400whp on a dynojet so i'm pretty happy with my GT2871r about now thanks everyone for your knowledge
4MationD! 90se RB26:build,95pgt KLZE swap:daily,92le vh45 swap planned
#2029 | |
Trader Rating: (26)
#2030 | |
Trader Rating: (58)
#2031 |
Trader Rating: (58)
If you're gonna go top mount, you'd be best off going with a smaller housing T3/T4 setup...just as responsive, much cheaper.
#2032 | |
Trader Rating: (26)
I've seen 330whp s14s run borderline 10/11s and 370+Whp s14s run 12s but trapping 11second soeeds.
#2033 | |
Trader Rating: (58)
Trap speed gives you a true HP. You have the weight, you have the distance...figure an average weight and you've got your 'whp'ET wise though you're right. The 60' is what matters most. Figure I went 11.65 with a 1.88 60', if I had that in the 1.60/1.50 range it would easily be a low 11.
#2034 |
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
I was just curious b/c I already have the 56 trim .64 a/r . Thinking about just buying the other housing and slapping it on a Mazworx manifold w/ external gate. B/C Topmount > Bottommount is what I keep hearing.
#2035 | |
Eagle rods ACL race bearings Brian Crower 264in/ex cams(only intake side has an hks cam gear) Brian Crower titanium valve springs and retainers Apexi headgasket 88mm bore 1.1mm thickness Greddy style intake manifold tubular turbo manifold Mototron 62lb injectors 300zx n62 MAF Garrett GT2871r T2 56trim compressor .64 a/r exhaust Garrett adjustable wastegate Greddy profec B2 CXracing sr20det frontmount intercooler w/piping Greddy RS BOV NGK bkr6e spark plugs shell 93oct gas and my tune is conservative once i hit what should be 400whp i was cool/happy with leaving it alone
#2036 |
i'll be going to the drag strip soon and i'm sure i'm around 400whp by normal standards after my tuned was done we put 2012 ss camaro on the dyno dynamic's and it only spun the rollers to 297.3whp and they make 360ish whp average down from 426 crank hp, what trap speed should i be looking for?... i've never tried on an actual strip lol
#2037 | ||
Trader Rating: (58)
FWIW: We've had SS's on our dyno, they were both in the mid 370's on our DynoJet. You gotta think those cars are going to see 15ish-20ish% drive train loss from factory. Load bearing dynos may be better tuning tools, but their power repeatability is often off. Heck even the V6 cars have been making good power
#2038 |
![]() Join Date: Feb 2010
numbers my set up made at 15psi on 91oct
Standard Block, standard Head.... Cosworth 1.5mm HG, ARP Head Studs, GT2871R .64, Z32 MAF, 740cc injectors, walbro 255, and a Nistune ECU Tuned By Seb at Specialty Z. |
#2040 | |
Trader Rating: (26)
Edit-Although I don't think my exedy hypersingle will be able to take that power. We will see.
