![]() Join Date: Nov 2006
are you serious ! :P id love to see how much you have to extend your front end to fit in the inline 6 (if ur thinking L series. v6 300zx thats another story) if you do get something of this sort. you should do a step by step or take pics of what you did maybe itl get sticky'ed out
MY 1991 240sx LE Hatchback |
#4 | |
![]() Join Date: Sep 2008
People put straight sixes in S14s all the time. A buddy of mine has an RB20 in an S14. No frame modifications at all. |
![]() Join Date: Aug 2008
Yea, if you really read the post, you would see that he was referring to the old L-series inline six from the old Datsun Z cars. I believe they are a bit longer than the RB series. |
#6 | |
I fitted a L28et into a S13 back in 1994.
I used the stock fs5w71b tranny that came in the 280zx. Most any car I do gets a custom driveshaft. I like to stay with a one piece and replace any center bearing driveshaft with the one piece. Mounts are close but sump needs a little bit of work and you have to make a custom turbo elbow to clear the steering shaft and I seem to remember that I had to lay the rack down a little to clear the T3 so a bigger turbo might net you clearance problems. It was a long time ago so details are sketchy. I put L series six cylinder engines into all of my nissans including my M30/Leopard. Luckily I dont' own a 510 or I would be in for a lot of fabrication. Last edited by Howlermonkey; 01-24-2009 at 08:27 AM.. |
^^^Howlermonkey did you have issues with the oil pan clearance? How'd you get around it?.TIA.^^^
We're doing an l28 in an S13. It mates up with the ka manual tranny fine. Maybe using a shorter automatic driveshaft to pull the engine back 2-3 inches. One of our problems, is the oil pan clearance. Sticking with the current Su's and stepping up to Weber's later. |
There's a build thread out there somewhere on this but I had the rear of the engine only about 3/4 of an inch in front of the firewall and I believe I only hit the swaybar which was relieved by pounding the pan in only slightly.
I used a first generation maxima oil pan which is a front sump pan but I think the datsun 810 had the same pan. You might be able to do some experimenting with crossmembers for a rear sump engine like a Z31 but not sure about the rack's distance from the control arms with that setup. Here's a thread from hybrid done pretty recently. l28et swap in a s13 240sx - HybridZ |
My current project is a L28et into a infiniti M30.
Went in easy as pie and turbo stuff clears steering gear and crossmember easy. Popped the tranny on the first drive a couple of days ago and am waiting for the ups man to bring me the clutch frictions and seal kit for the worked 3n71b auto with high stall speed torque convertor. Same type of mods required to fit L28 as in S13/14. Engine mounts have to be cut down because engine is too high. Have to switch over to front sump oil pan and extend pickup and make custom turbo drain. |
![]() Join Date: Sep 2006
dunno,
the real qustion is why? at best the Sohc L28et will do what ....? 300whp @best 500whp with alot of custom parts.... RB25det swap = 300whp from the box 2JZ-GTE (not GE BS) is 280bhp stock with cams + DP + 15psi of boost that an easy 380-420 whp (USDM turbos) oh well every one has his own
'95 S14 Se With HKS's - BREMBO's - ES/SPL. |
My total expenditure on this car including purchase price is 1400 dollars and it's good for 270hp the way it sits which is 110hp more than it had when stock.
It's unbelievably quiet, easy to drive and pretty damn fast with the a 3n71b auto and high stall speed convertor. I have a L28et F54 block with td06-20g, forged pistons, and a worked P90 head with a good cam on the engine stand in case I want to make 450hp but my goals for this car are different and the extra budget numbers work against the spirit of this project. I'm still mulling over whether to fit the FS5R30 tranny into this car using the adapter I bought from Austin Hoke at hybridz but that depends on whether the 3n71b being worked on my kitchen table holds up but that will add 600 bucks to the project bottom line. Sure I could build a 1000hp RB30 with RB26 head but my goal is to use a 1981 engine in a 1991 car running on a 2001 ecu and pass 50 state emissions with it in leather lined comfort with working A/C and power steering. I can also flash new tunes to this ecu with a vetronix master tech, blue streak iFlash, blue streak global programmer, or a host of other programmer/scan tools without doing anything more than hooking it up to the obdII connector. Who knows.....maybe the big engine will end up in a 240sx but I would rather try to fit it to a s12. Anyway .......back to L28et into 240sx. I would recommend using the fs5w71b tranny over the T-5 and, depending on where the bellhousing sits with stock motor (don't remember), you might get away with using the stock 240sx driveshaft. If you are using the 280zx turbo automatic, you would either need to fit that tranny specific yoke to the 240sx driveshaft or lengthen the 280zx turbo driveshaft as well as fit the rear u-joint and flange to the lengthened driveshaft since I'm not sure if the 280zx turbo specific flange can be swapped into the short nose r200. |
