#241 | |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
I grabbed it from AGP turbo, they have the weld on elbow option for like $40
#242 |
Well, as usual I am blessed by the fortunes of bad luck. After getting it all together i drove it to work. Everything was great and was a blast to drive. On the way home, i lost all oil pressure.
Seems the oil pump or a seal failed. Out came the engine. Inspected everything and it all looked fine. I replaced the oil pump, all the seals and gaskets on my way out. Seems I got lucky and the drop in oil pressure didn't trash the engine. Full boost(8psi atm) seems to be 3700rpm, this turbo is awesome (Use headphones)
#243 |
Been driving around breaking stuff in. Boost is about 10 psi currently, afr's still in the 10's. Gonna take a few to get used to this trans, gears are super close together. Needs an alignment bad.
#244 |
Went and got an alignment, turns out the drivers side strut tower was pushed in. This made the alignment wonky. Had a odd knocking in the rear, i ripped a subframe stud from the body.
Parted out. /build.
#246 |
Fuck all that shit. I'm so done with that.
So after a quick 5 day part out. I was able to get a new chassis to play with. Picked up a 1993 jzx90 Chaser Avante. It's all original, never modified, has 16k miles on it(after converting from km). It's a stock na 1jz, with auto. I'm so stoked to to get it. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
