#5671 | |
head light bracket placement
Thanks for your time. |
#5672 |
Don't mean to ask for all the secrets... The one thing I was worried about is that currently my car has a 20 deg rake, as it it is jacked up under the rear subframe. I don't want to start fixing locations and orientation of the lamps until I get the car at the correct ride height. Did you turn the headlights and aim them before you set up the brackets? Sorry for all the questions.
#5673 |
![]() Join Date: Jul 2006
![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Such a baddass thread!!! Huge props to all fabricators, welders, and DIY enthusiasts. Heres some of my work from the passed couple months...
Just finished up a custom turbo system for a R35 GTR using twin EFR 7670's Also squeezed in a custom SR turbo kit for a Datsun 510 Made a custom exhaust system for my motorcycle to clean things up. If anyone is interested in these projects or other crap I have going on, follow me @Jamison182 on Instagram. Cheers! ![]() Last edited by Jamison182; 11-06-2014 at 09:53 PM.. |
#5674 |
![]() Join Date: Aug 2011
What's your secret?! |
#5677 | |
![]() Join Date: Oct 2009
i've also got a question. what method/tool do you use to cut your merge collectors? i built a jig to mount on my chop saw but i'm not happy with the quality of the cut i'm getting from the saw. i'm curious what tool others use to get the best cut, but still be able to get a 10-12 degree cut. ps that R35 setup is excellent. very nicely packaged. |
#5678 |
![]() Join Date: Sep 2007
Big band saw with either a 3/4" or if you have the $ a 1" tall blade. Cuts a lot more straight than your typical half inch blade on a small saw.
www.facebook.com/HellaFab |
#5679 | |
Here is a cut jig made by PRL. I've never used it, but it looks like a great idea. Might not be the most practical for larger scale production work. I like how the clamping system keeps the elbow from spinning. |
#5680 |
I have the 1st gen walefab collector cutter.
I designed it and he came up with the machining details. It works great.
#5681 |
yeah i'm not concerned with production times at all. i just fab for myself in my garage. i've been attempting some header collectors and things of that sort but i'm getting sub par results from my current setup. my band saw doesnt have the throat depth to cut an 11 degree cut on a 2-3" tube unfortunately.
#5682 |
![]() Join Date: Sep 2012
bump this joint.
ive been looking for pics and DIYs for people that have modified their rear quarters. like for rolling them. instead of hacking up the rear quarter, I was thinking of separating the inner lip of the wheel well then cutting or drilling out the spot welds to have the outer metal be able to bend more and then reinforce it with a plate or something. Its hard to explain, so if anyone has pics or links that would be great. |
#5683 | |
Edit, damnit SteveO just ask this on MA? And why haven't I fixed my location on the Z yet?
'95 240 | @SleepySteve72 |
#5684 | |
#5685 |
Thanks man! That's kind of what I've been looking to do... I actually ended up sourcing some NSX lights which have adjustability built into them. Originally I was going to use lights I hacked up from a subaru SVX. But even trimmed down they are just too wide to get in to the headlamp bucket. The NSX lights will be way easier, and afford the adjustability to aim them right! Keep up the good work, and thanks for the response.
#5688 |
#5690 |
Neat, any pictures of the inside of the runners?
#5692 |
Its been a busy week for me and my project hatch. I cleaned up some the coolant lines under the I.M. and made a stainless loop to bypass/delete my heater core
I put the finishing touches on my exhaust manifold and welded a 90 degree elbow to the compressor housing. Tacked up a few more bars to my cage late last night too ![]() |
#5695 |
![]() Join Date: Oct 2006
While I like the coolant loop to eliminate heater hoses. . . isn't that gonna rub the firewall? Just wondering, I went a different route myself. Interested to see that fits, looks good!
#5696 | |
Thanks homie!!! Post that V-mount!
#5697 |
Oh Cool, you work at FFTEC right? Cool stuff mang, really nice work. Are those the Tial housings for that GTR?
![]() ![]() ![]() ![]() some of the nicer photos off my broken ass phone. |
#5698 |
Thanks man. Your work looks really nice too! Yeah I run the production fab over there for a 9-5 and run my own custom fab operation on the side. But to answer your question about the EFR's, no, no Tial housings here. Cheers.
#5699 |
![]() image search Angle kit by me. Geometry corrected. CNC assisted kit coming soon. All geometry on coming version will be as close to ideal as I can get it. Kinematics will be plotted and tested on solidworks, and then driven and tested in real life in pro-am fd. I'll definitely be posting up that stuff in a lot more detail. Drivable kitsare a couple months out, and solid works models should be done next month (hard between work and school). Awesome engineering extra credit though haha. ![]() image sharing Just finished turbine outlet. Kind of crappy pic of it. But it turned out pretty well! Fitment is prettydang on point. 3.5" v-band, flexpipe with larger I.D. and mandrel bent "elbows" used for curves. 3-3.5" cone adapter to 3" turbo outlet.I love seeing everyone's fabrication! I'm still a noob, but I'm learning.I have so far to go though lol. |
