04-08-2012, 03:00 PM | #1 |
suspension pop/thud noise???
Sup peeps, I drive 95 s14 with k-sport slide controls and cusco arms, so I have this kinda pop/thud noise on the driver side rear i only hear it when the car has been sitting for a little while, ill go out to open the door and hear the sound if that doesnt trigger it then sitting in the car triggers it, anybody else had this problem, if so what should i be looking for? thanks
04-08-2012, 04:29 PM | #2 |
Sounds like something is unloading when you shift some weight in the car. See if you can take a look while someone else opens the door or sits in it.
My SR20VET |
04-11-2012, 12:32 PM | #4 |
bump... im still hearing that thud sound jacked the car up and took off the wheel to really take a look at things and everything looks real good idk why its making that noise errrr, anybody else care to share there ideas?
04-11-2012, 12:35 PM | #5 |
Trader Rating: (35)
Feedback Score: 35 reviews
When my car started making "popping" noises, i checked out my arms weren't lubed, so i lubed the bushings & hardware and the popping stopped. maybe that could help you
04-11-2012, 12:37 PM | #6 |
Trader Rating: (31)
Feedback Score: 31 reviews
What edwin said... lube those heims
VISIT OUR NEW SITE! streetfaction.net |
04-11-2012, 08:03 PM | #9 |
WD-40 will make your parts rust... Use a silicone lubricant spray, white lithium grease, etc... Now that I think about it, it could be your coilover springs too. They tend to twist on their seat as the spring is compressed/uncompressed.
My SR20VET |
04-29-2012, 01:06 AM | #11 |
Hey guys.... lol sooooo im still getting the thud sound. So far i have jacked the car up removed both wheels sprayed everything with break cleaner, I let it dry sprayed everything with dry lube, cleaned the coilovers checked the springs checked the arms and all, everything looks clean and good, I have rear subframe collars not sure if maybe thats the cause, and also I DD this car and granny drive it. I shift gears at like 2500rpms or so and i feel as if the rear is lightly catching/thud(i have a nismo 2way) everytime i shift other than that the car drives smooth. i need help figuring this out! Im highly considering getting those parts shop max solid bushings what do you guys think?
04-29-2012, 09:24 PM | #16 |
Has your subframe had new bushings installed?
My SR20VET |
05-01-2012, 02:15 PM | #17 |
No, looks like the previous owner cut the bushings and installed some blue aluminium collars kinda doesn't look right... bottom collars aren't even flush against the sub frame wondering now if that's partiality the problem
05-01-2012, 04:02 PM | #18 |
Yep, I'd be looking for replacement bushings for the subframe...
My SR20VET |
