![]() Join Date: Aug 2003
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
1\4 Mile Times
Just wondering what kinda numbers we got out there... and mods too
My best time was [email protected] Redtop. Greddy FMIC & hard pipe kit, full exhaust, intake, 240sx MAF.
89 240sx hatch #933-the hot rod 91 240sx coupe #131,603-the daily |
#2 | |
I don't have a 240, but in my B13 Sentra w/ T28 I would have probably been in the 12s, but I have no proof (never made it to the track before the move to FL, but people with similar mods have hit mid-high 12s with ease). That is with 10-13psi, 3" turbo back, spearco FMIC, Z32 MAF, JWT ECU, Fidanza 9lb Flywheel, MSD 50lb inj, UR crank pulley, and a few other things... Josh P.S. I hate being on here talking about my B13, but hey, its all I have to talk about at this point ![]() |
stock 8 psi, and the car has never ben tuned since the swap.... i need a better fuel pump cuz i have a stock 240 fuel pump...
#4 | |
What was your 60'? R/T? Josh |
on my 13.78 run i had a 2.01 60 and a .590 reaction, but i had a stock clutch then and dry rotted tires so i could slip the clutch now i have a 6 puck, stage 3 pressure plate and its really hard to slip... i havnt run my car since the new clutch set up and my new falkens.. and im ganna get a supra fuel pump i think cuz my friend works at O,rielys(southwest autoparts store) and can get it at cost but i dunno how big a supra pump is, i heard same as a walbro 255.
I am pretty sure the Supra pump is 290lph, and usually a bit more expensive (dont know what they are at cost, maybe cheaper than a walbro) than a Walbro.
The times seem pretty good especially under those conditions. Im sure you could knock a couple tenths off with some tuning and whatnot. Josh |
It seems that SR's dont have any balls up top... My freind has a turbo RSX and he ran a 13.9 @ 104, and anothe freind of mine has an all motor prelude and he ran a 14.5 @ 99.
and a 290 pump.. thats to big does anyone know what a stock 300Z TT pump is??
![]() Join Date: Aug 2004
i dont think a supratt pump is a 290; its like a walbro 255, it is more efficient in some areas and some areas it isnt... cant remember the specifics...
i THINK the Z32TT pump is a 290 though... as far as not having balls up top; check out duey's car that just posted 111mph traps... thats way more balls than the little times you just posted ![]()
95 Lexus SC300 5-speed -DD pimp car 92 Nissan 240sx base coupe -clean KA24DE swapped in -GTIR T28 -Big FMIC -565cc STi Injectors w/ Z32 MAF -J30 VLSD w/ subframe spacers -RPS Max clutch -3" turboback -PLMS Daughterboard on modded ECU |
#11 | |
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
i ran a 14.6 with a stock sr and stock clutch shitty tires and stock boost with catback....side mount etc.... then i did all my mods, i should run mid to low 13's but i still need better tires and an lsd
and alot of other things but thats what i run now
![]() Quote:
12.3 is fast, dont get me wrong, and NO offense to duey , that car is badass, but a lot of other cars would be going faster than 111mph running that same time... i think its just that SR's are all down low, maybe its just the T25? thats why i want more people to post there times a mods...
![]() Join Date: Oct 2001
![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
on my first night ever on the track i did a 14.07 at 101.01
red top, T25, unknown boost (est. 10-12psi) untuned SAFC, 6 pucker, full 3" except for a 2.5 cat that i havent been able to swap out yet. i've been told that the trap speed is good for a much lower time. i bogged several launches, call it nervousness.... i figured that was pretty good for a base run, and i know i can hit the high 13's with some tuning and practice. suggestions? |
#16 | |
![]() dude thats with a STOCK TURBO... there are PLENTY of turbos that will BOLTON in that stock location and produce far more power... GTIR turbod cars generally run in the 115mph range... GT25R and other GT variants can run 120mph+ how fast do you want to go? we're just talking T25-flanged turbos here... if you start getting into top-mount turbos, you're looking at WAY more power... running 111mph on a little stock T25 w/o nitrous is MOVIN... oh and i'm sure duey used slicks or cheaters for a 12.3 at 111... you should go ride in a upgraded-turbo SR20 car, my friend's GTIR-turbo S13 is pretty quick pulled just fine to redline heh
#17 |
![]() Join Date: Sep 2004
[email protected] 86.7mph, Pretty much stock, header,and exhaust w sub in trunk.
------------------------- www.carolinanissans.com ------------------------- |
#18 | |
260 lph @ 43 psi; 220 lph @ 58 psi; @ 12 V 1. 290 lph @ 43 psi; 260 lph @ 58 psi; @ 14 V 1. Josh |
#19 |
11.71 @118.54 16psi boost
Bone stock 115,500 mile KA with PK turbo kit, PK intercooler kit, PK fuel system, AEM EMS. 91 hatch, full weight, AC working, PW, PDL, Sunroof, etc spare tire and jack were removed running on 24.5-8-15 MT ET Drags on the rear http://www.phatka-t.com/projectcars.htm
Ivan www.PhatKA-T.com www.sound-performance.com
#20 |
![]() Join Date: Apr 2003
wow, i swear, the KA-T is volatile compared to SR crap i've seen. I'm doin a KA turbo next 240 project i do. I've yet to run my car at the track, but w/ 2.5" exhaust, FMIC, BOV, Boost Controller, fuel pump and year old fuel (car sat for a long time) i dynoed 210 whp at 8 psi
now i've got all the exhaust goodies 3" to the bumper, 14 psi, hopefully i can pull off mid-high 13's at the least |
#21 |
This paticular car dynoed 305 whp on 10psi of boost and 405 whp 409 TQ on 16psi boost.
Aything much more then 400whp the ring lands on the stock KA pistons crack. I am currently building a forged piston motor with strengthened stock rods to see how much HP I can get out of the stock long block plus pistons. Everything on the KA seems to have been overbuilt or with boost in mind except for the pistons. I was so impressed with this motor / car, I decided to build an all out drag race car with the KA motor which can also been seen at the link above.
#22 | |
BTW that things is bad ass, good work on the KA-T |
#24 |
Thanks guys. All the pictures on the web page are of either Heath & Keith's S13 or my S14. http://www.phatka-t.com/s13manifold.htm shows some of the beginning stages of the build before coatings and such. I have been lazy and didnt really get many pics of the completed setup. http://www.phatka-t.com/s13intercooler.htm shows the intecooer setup prior to powder coating. Their car is back at the shop after breaking ring lands on the second bone stock motor. I should have the block, crank, head, rods, and pistons back from the machine shop this week some time and I will be building that motor and getting it installed. I will get some good pictures for sure this time and get the web page updated. I will also be putting larger injectors in, a Mitsu ballast resistor pack, and turning the boost up to see what this motor can make. I am shooting for around 500whp and hope to knock down a 10 sec time slip.
#26 |
never draged mine with the stock T25.. but it felt decent i'd say... i had many cars in the past so i wasnt too impressed with a performance of the small t25.. but ran a friend the other day with an 02 m3.. had 11lbs.. and took him of the line till 4th gear when we had to shut it down by half a car.. never was even able to pull on me. Now the car has a 2871 stock boost is 10psi.. tuned it yesterday to set a/f ratio and went as high as 18psi.. sound pretty scary.. hopefully that will be some 11's if i do go the track and can hook up..
#27 |
![]() Join Date: Apr 2004
i ran a 14.80 at 99mph. with a s14 sr, with downpipe exhaust and intercooler. But i have stock tires which equals no traction, and just like you bing i have been told that with my trap speed i should have a lower time.
#28 | |
uhm according to some research i've done [email protected] is about the average time i should be running with that trap speed. btw my max rwhp is at 5k so it's not like it's really down that low. |
#29 |
maybe i was shifting really bad... cuz 13.7 at 94 seems weak to me... but thats my car, all im saying is that iv seen a number of other car with 5-10mph trap speed than that at around the same 1/4 mile time.. hell i wish i could run a 12.3 @ 111mph. I have no tach... maybe i should get mine fixed... i had a SOHC do i have to replace it or is there an adapter to make it read millivolts.
#30 |
![]() Join Date: Jul 2002
When I had my SR I raced a B18 swapped civic that ran a 13.9 and I beat him by about 4-5 cars... soooo, mid 13's I'm guessing. Never ran the 1/4, hate myself for it, but, just some info for ya.....
