![]() Join Date: Jan 2012
1998 Nissan 240sx KA24de ecu codes
before anyone says anything i have done all the steps correctly and more than once. i have also used google to search for this code and can not seem to find it. Here are the codes i am getting from my ecu...34 which i know is the knock sensor and 412. i am not sure what this 412 code is but i get four slow flashes and 12 fast flashes. when i get better lighting in the morning i will video tape it and post it online to prove that i am getting this code. Anyone have any insight into this mysterious code?
![]() Join Date: Dec 2008
The only numbers that should come up are between 11-128.
That's strange if in fact you are getting a "412." Here's the list of codes: How to Read Malfunction Codes for Your DOHC 240SX Items DTC Ref. Page Camshaft Position Sensor 11 EC-88 Mass Air Flow Sensor 12 EC-92 Coolant Temperature Sensor 13 EC-97 Vehicle Speed Sensor 14 EC-101 Ignition Signal Primary 21 EC-105 IACV-AAC Valve 25 EC-110 ECM 31 EC-115 EGR System 32 EC-117 Front O2 Sensor 33 EC-125 Knock Sensor 34 EC-130 EGR Temp Sensor 35 EC-133 EGRC-BPT Valve 36 EC-137 Closed Loop 37 EC-139 Intake Air Temp Sensor 41 EC-140 Throttle Position Sensor 43 EC-145 CYL 4 Misfire 65 EC-150 CYL 3 Misfire 66 EC-150 CYL 2 Misfire 67 EC-150 CYL 1 Misfire 68 EC-150 Random Misfire 71 EC-150 TW Catylist System 72 EC-154 Fuel Injection System 76 EC-157 Rear O2 Sensor 77 EC-162 Crank Position Sensor (OBD) 82 EC-167 A/T Diag Comm Line 84 EC-171 Crank P/S (OBD) Cog 95 EC-174 Coolant Temperature Sensor 98 EC-178 Park/Neutral Position Switch 103 EC-183 EGRC Solenoid/V 105 EC-188 Inhibitor Switch 111 AT Vehicle Speed Sensor A/T 112 AT A/T 1st Signal 113 AT A/T 2nd Signal 114 AT A/T 3rd Signal 115 AT A/T 4th Signal or TCC 116 AT Shift Solenoid/V A 118 AT Shift Solenoid/V B 121 AT Overrun Clutch S/V 123 AT TOR Conv clutch SV 124 AT Line Pressure S/V 125 AT Throttle Position Sensor A/T 126 AT Engine Speed Signal 127 AT Fluid Temp Sensor 128 AT A/T Comm Line XX EC-192
1990 Nissan 240SX w/KA24DE - New project 1984 Mazda RX-7 GSL-SE 13B |
yea i know. im gonna try and video it if i get the code again. The day i posted this thread i had checked in 5 times and i got the same code every time
