Raising rear coilovers...
Just installed a used set of Megan Streets on a S14 and need some guidance. The rears are slammed and I want to raise them, but I'm hesitant on twisting the shock body much as I don't have any indication of when they'll disassemble on me...
Is there any way to tell when I'm close to unscrewing the whole thing apart? Even if it doesn't come apart, I'd hate to unscrew them to the point where there's only a few threads left and ride on that. Unless if I'm at this point, the ride would be ridiculously high where i wouldn't want to be anywhere around. Any help would be appreciated. Thanks! |
![]() Join Date: May 2010
![]() Feedback Score: 21 reviews
Im not sure if knockoff parts come with instruction manuals, but have you tried reading the instructions? My fortunes came with a nice explanation of how to adjust height, and the max you can safely put them up.
![]() Join Date: May 2011
Dont see how there knockoff but people have there opinion's. I have megan track series and i lowered the shock body all the way down and measure how deep it is and then raise it to where it was bout inch before it came out
http://legitjapan.wordpress.com/2012...for-that-kouk/ |
![]() Join Date: Sep 2006
hmm.. i also fail to see the connection between megan COILOVERS and knockoffs. cheap/inexpensive/budget/entry-level? yes. knockoff? not really.
i doubt youll raise your car enough so that they would disassemble. i thiiiink they are designed to be at least manufacturer ride height.
formerly known as "hotboiblaze" ![]() ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
Man w/ CTSV & a Car Seat
If you're just raising it up, there's no way in hell you'll unthread the body out. As long as you dont decide to raise the car up over a foot, you should be good.
As far as Megans being knock offs...you know there's not really such a thing as "knock offs" for coilovers? They're all made by the same fucking Taiwanese company (Section) that makese name brand coilovers. Most of the time, the only difference between them is that the name brand ones have a more stringent QA and specific valving. You ever noticed that MRs look exactly like the A'pexi? |
