Motor: SR20DET redtop w/S15 spec-R T28
OEM wastegate actuator I am trying to find a new replacement for the small piece that holds the wastegate actuator arm to the wastegate flange. Its like a little clip that clicks into the little recess on the pin, and I am looking for the proper name or part number. I don't know how well that explains it, I will try to take a pic of the spot it attaches to tomorrow for better reference. Once again its the little locking tab that keps the wastegate actuator rod from popping of the wastegate rocker flange. I was considering going to a junk yard and taking one off from a TT 300zx T25, but I'd prefer to get a new one, because the exhaust heat can make it brittle and I don't want to go through loosing another one... Thanks for any help you might be able to provide... |
Man w/ CTSV & a Car Seat
You already answered your own question...go to the dealer and tell what you're looking for but use a Z32 TT as a reference. Usually, theyll print out a picture break down of all the turbo component, dont see why they wouldnt have it in there. You see it, point at it and order it.
Thanks for all the help, and I checked Courtesy Nissan first before posting this, and in the factory turbo parts breakdown it did not have a part number for it under the Z32 TT section that is why I posted this.
Again, thank you all for your help and assistance. |
