S14 to S13 window motor swap???!!!
Ok , Were i am at it is hard as hell to find a driver window regulator for my S14 , question is , would a S13 reg. work my S14 ..?????
![]() Join Date: Dec 2002
S14 uses a scissor arm regulator while the S13 is cable driven. Nowhere near the same.
Maybe you can't find one because you haven't looked in the right place, a new regulator at the dealer is only about $35. If you can't afford that you need to find a new hobby.
The window amp can be swapped. Though the part number is different that's only because the bracket that secures it to the door is not the same. The amp is, from 89-95. Later models didn't use an external amp.
