Feeler. 90 cressida FS 6k obo
![]() ![]() ![]() ![]() ![]() I have a 90 cressida with a fresh imported 1jz non VVTi and r154 transmission out of a jza70 (so no traction control!). It has -mishimoto radiator and new hoses -rear sump oil pan -new belts and tensioner -ac and powers steering are deleted but I have everything to hook it back up -SS power steering hose -new water pump - 3" y pipe -XM engine mounts -XM transmission mounts -XM clutch pedal and master cylinder -XM one piece driveshaft -3" SS exhaust -lowering springs -GTR front mount intercooler -locking hood pins -driftmotion fuel dampiner bypass hose -engine bay painted glacier silver Runs and idles smooth, and turbos spool great. Haven't had a chance to get it on the road, because it needs a map sensor ans i haven't had time to bleed the clutch and put tranny fluid in it. It also needs cooling fans, a new front right break line, and the hood latches installed. The chassis is a clean pearl white no rust and a straight body, with sunroof. The interior was originally blue but I have died everything black. The front seats aren't in good shape and the top of the back seat is sun faded and cracked. I'm only looking to sell as i have found a car to buy. I habe 9k into the car but i need to sell it asap, asking 6k obo!!! Last edited by Y0SH; 05-22-2015 at 09:05 PM.. Reason: Added parts to list |
I really didn't want to bump this because I had decided to keep the car, especially after getting it running, but money is tight right now. If it sells, I know I will regret it, but it would probably be for the best at the moment. 7.5k obo. If I was to trade it, I WILL NEED CASH ON TOP!!!]
Bump. 6k obo. Got a job and need the cash to get something reliable. Car starts and runs but it needs a map sensor. Ive also started pulling the rear fenders to fit wider wheels.
| 1jz, 5 speed, cressida, mx83, sedan |
