Lots of 240SX parts - stock/aftermarket
It's time to clean out all the parts I found in my basement. All prices are OBO...make an offer. Willing to ship at buyer's expense. PM or post with questions/offers, thanks...
Clutch pedal - $15 Clutch master cylinder w/ hard line - $20 S13 stock RUCA's - $10 S13 stock toe arms - $10 1990 240SX factory service manual - $15 KA24DE stock flywheel - $40 N60 MAF w/ pigtail - $45 SOHC KA MAF - $25 DOHC KA MAF - $25 S15 SR20DET stock 550cc side-feed injectors - $100 SOHC ('90) KA M/T ECU - $35 DOHC ('91) KA M/T ECU - $35 SOHC gauge cluster (x2) - $15 each S13 gauge cluster surround - $15 S13 Whiteline rear sway bar (brand new with bushings and end links) - $100 S13 stock tension rods w/ energy bushings - $30 Nagisa ultra-low side mount seat rails (driver's side-barely used) - $100 S13 center vent gauge holder - $10 60mm Greddy electronic oil pressure gauge - $100 S13 SPL SS braided brake lines (rear, brand new unopened) - $40 Autometer A-pillar gauge mount (never installed) - $10 S13 Energy poly bushings for rear arms and knuckles - $30 Brembo 4-lug front rotors (no ABS, not drilled/slotted, brand new) - $30 Temperature sensor port for radiator hose (1/8 NPT, 36mm OD) - $10 Circuit Sports braided SS turbo lines (SR20DET bottom mount) w/ drain flange - $90 GTiR SR20DET T28 stock compressor housing - $25 RB20DET stock turbo outlet with O2 sensor - $20 RB20DET ebay SS downpipe w/ O2 bung (bolted right up with the stock turbo outlet) - $50 Last edited by _jonesy_; 10-07-2009 at 04:23 PM.. |
I will take the sr 550's and the temp sensor port. Thanks
[email protected] |
$20 shipped, my paypal is [email protected]
460
2 bump limit. You can start new thread in 3 days.
