Old 11-08-2002, 05:46 AM   #1
adey
adey's Avatar
adey is an unknown quantity at this point
I finally received my momo wheel in the mail today, and like a school kid with a new toy, I was anxious to try it out!
The install (with HKB Hub) was straightforward enough, including the horn button. But, after all was on and Tight, I took the car out to see how it felt. The first thing I noticed was how stiff and heavy the steering wheel felt, I could barely turn out of my parking space! Then when I got out, I noticed that I had to manually wind it back to straight-forward position! It wouldn't wind back by itslef!
So figuring it'd be better when I got up to speed, I turned out of my parking structure, to find that even at speed, I had to use excessive force to turn the wheel back straight.
I have no idea why it's suddenly so ridiculously hard to steer. The wheel is a Momo 310 (300?) mm wheel (small, I know) but even then, I don't see why the wheel shouldn't return to the 12 o'clock position.
ideas? <img src="#/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
adey is offline   Reply With Quote
Old 11-08-2002, 09:21 AM   #2
s13driver
s13driver is an unknown quantity at this point
it sounds like your power steering is dead more than anything else... but i could be wrong.. <img src="#/f/iB_html/non-cgi/emoticons/butbut.gif" border="0" valign="absmiddle" alt=':but:'> &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/hmmm.gif" border="0" valign="absmiddle" alt=':hmmm:'>
it is so hard to educate the uneducated.
s13driver is offline   Reply With Quote
Old 11-08-2002, 09:39 AM   #3
AKADriver
AKADriver's Avatar
AKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura about
Sounds like there's something binding somewhere. &nbsp;dead power steering would lighten up at speed and still easily return to center.
AKADriver is offline   Reply With Quote
Old 11-08-2002, 11:08 AM   #4
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
and smaller steering wheel would make it heavier
and so would a dead power steering
however it should come back after a turn....
so i am guessing u did something wrong.. maybe over tighten something when u did the steering wheel
if it isnt too much of a bitch then put your OEM one back on
I am GOD!
drifterx is offline   Reply With Quote
Old 11-08-2002, 04:02 PM   #5
adey
adey's Avatar
The first thing that came to mind was that I had lost Power steering... but that didn't really explain the steeringwheel returning to 12 o'clock position so slowly and tediously.
I didn't really describe my problem too well last night, I posted just before bed.
It's not that the wheel doesn't turn back to 12 o'clock position, rather it doesn't turn back nearly as fast. When I let go of the steering wheel when it's at full lock (and i'm moving) I will still move in an arc for a long time before it straightens completely back to 12. &nbsp;
What might I have done wrong? I take it I couldn't have over-tightened the center nut, could I have?
Also, is there any way to wire things up so that the blinker return tabs work? (i.e. blinkers turn off when I turn back after a turn.)
Old 11-11-2002, 02:55 AM   #6
adey
adey's Avatar
bump: weekends are always slow. &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/lookaround.gif" border="0" valign="absmiddle" alt=':look:'>
Old 08-21-2004, 03:25 PM   #7
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
sorry to bring a thread back from the dead, but i'm having the same issues with my wheel... is there any way to correct this? also, my horn button doesn't fit in my wheel because i think i'm missing a piece that was supposed to come with the hub, which attaches to the back of the wheel in order for the button to fit correctly... right?
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 08-22-2004, 02:02 AM   #8
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
ideas?
Is the HKB hub the recommended hub that Momo suggests using with the steering wheel? How's the clearance between the back of the hub & the steering column & cover? How did you thread the horn hot wire/ground wire thru the hub? Sounds like maybe one of the horn wires rolled around the steering column where it bolts up to the hub causing it to bind somehow. If you've got a digital camera take a picture & post it....we might be able to spot the problem...
Anyhow, hope this helps...
Good luck!!!
ID
'95 SE
idlafie is offline   Reply With Quote
Old 08-22-2004, 02:38 AM   #9
kingsol
this thread is super old... i just brought it back because there were unanswered questions... maybe i should just start a new thread...
-Emerson
