Old 12-31-2008, 11:12 AM   #1
mikeroy420
mikeroy420's Avatar
mikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-known
LSD install problem
I just had my limited slip differential installed at a dealership, and now I'm not sure if the axle output shafts were installed in the proper sides. I'm having the same problem as the one in the following link Cusco 2 way problem - Zilvia.net Forums. Does anyone know which axle shaft is susposed to be closer to the ring gears? the shorter one or the longer of the two?
mikeroy420 is offline   Reply With Quote
Old 01-01-2009, 01:01 AM   #2
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
Why does everyone freak out on this?
There are snap rings one is in the diff, and one is on one axle while the other axle just has an empty spot for it. There is no screwing it up, if you do one axle wont keep itself in there. Can you pull it out by hand? No? your good then.
4x4le is offline   Reply With Quote
Old 01-01-2009, 01:08 AM   #3
hayaimoto
hayaimoto's Avatar
hayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud of
I think what he is refering to is that his axle stub flanges are from a viscous model lsd, and he does not know which side the axle flange mounts onto.
Viscous model axle flanges are different in length.
Refer to a FSM if possible or if this is indeed your question let me know, Ill find the answer for you.
hayaimoto is offline   Reply With Quote
Old 01-01-2009, 01:22 AM   #4
4x4le
4x4le's Avatar
Yea, Im thinking thats what he is saying too and although I cant remember from when I did my tomie 2 way lsd in my 180sx vsld which half shaft was actually longer but one has a snap ring and the other dont, the other snap ring is in the carrier. You should be able to see it with a light or feel it with your finger if its long enough (maybe not if its already in the diff case) but the half shaft without the snap ring needs to go in the side of the diff that has the snap ring in it.
If you take the half shaft without the snap ring and stick it in a side and it holds, its in the right side, if it dont its in the wrong side so put it in the other side and it will hold, and then put the other one in the other side and youll be good.
Old 01-01-2009, 01:28 AM   #5
MrMcgarrett
MrMcgarrett's Avatar
Trader Rating: (313)
MrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfection
Feedback Score: 313 reviews
Send a message via AIM to MrMcgarrett
Short one goes on the left side.
MrMcgarrett is offline   Reply With Quote
Old 01-01-2009, 07:02 AM   #6
mikeroy420
mikeroy420's Avatar
I couldnt find anything in the FSM. It's open diff. It looks like both sides have snap rings to hold it in place.
The short one goes on the left, thank you.
Old 01-01-2009, 04:08 PM   #7
4x4le
4x4le's Avatar
wait, so the dealership put in a open diff?
Old 01-02-2009, 06:01 AM   #8
mikeroy420
mikeroy420's Avatar
Sorry, they removed me open diff to install my nismo 2way lsd. When I got it back, the shafts looked incorrect.
Old 01-02-2009, 06:37 PM   #9
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
When i first did my lsd instsall i installed mine on the wrong sides. had to drop the thing out and start over.
im really supprised a dealership put in an artermarket lsd, my dealership wont even install a nismo clutch.
redsx13 is offline   Reply With Quote
Old 01-02-2009, 09:17 PM   #10
4x4le
4x4le's Avatar
actually they arnt supposed to give you any trouble with nismo parts. I guess maybe they can if you didnt get the part from them as it could be fake.
