SR idle issues
Okay so my car isnt holding idle until a few minutes after manually holding it. I first blamed the issue on the maf because it would idle fine if unplugged it, but with two new(used) mafs it does the same thing. When it does finally decide to catch idle it is not because the car is warm, because if i turn it off and back on it wont idle again. i did find one injector was sucking air but after fixing that the issue is still there. It is idling anywhere from 11 to 15 afr, it isnt very consistent, but does only change slowly, unless I give it gas. When i give it throttle a it goes super lean 16+, but does seem to hold better afrs for around 30 sec after (around 14 to 15) after this it will drop to 11 or so over about 10 seconds.
Basically just looking for any info or if anyone has had a similar problem. I know to check for vacuum leaks, none of the injectors seem to be stuck, and the fuel pump and pressure are fine. And i know it sounds like a maf problem, but what are the odds 3 mafs are bad, in the same way. Ty for any help or tips |
vac leak
10 char
@UpshiftEngineering |
#4 | |
your symptoms scream 'unmetered air'
