1989 Toyota Supra (1JZ)
SOLD SOLD SOLD SOLD SOLD SOLD
SOLD SOLD SOLD SOLD SOLD SOLD Body 1989 Toyota Supra Turbo Shell Clean Arizona Title Original White package JDM dark red taillights FD3S RE-Amemiya Carbon Diffuser JDM bubble sidemarkers European half amber half clear turn signals Battery relocated to truck. AGM battery. 450hp 400tq Engine 1jzgte VVT-i 1ZZ/1NZ Coils AEM Infinity EMU Kaizen Motorsports Engine Harness Drivetrain R154 Oem flywheel ACT 6 Puck Clutch Stage 3 One piece aluminum driveshaft ACT pressure plate Polyurethane trans mount 3.73 LSD Marlin crawler shifter socket Marlin crawler shifter bushing Aisin Slave cylinder High pressure steel braided Clutch line Fuel System ID 1050x Injectors Radium Engineering Fuel Rail Radium Engineering Fuel Pulse Damper AEM Flex Fuel sensor Walbro Hellcat 525 pump Turbosmart FPR1200 Black Full -6AN Feed and Return PTFE fittings and lines E85 Freaks 7 micron filter Wired for dual pumps Turbo/Exhaust AGP Zeta 3.2 1.00 A/R hot side Future fabrication one off Turbo manifold 1 inch manifold spacer 3" Downpipe Full 3” straight exhaust to dual 4” tip Tial 44mm MVR Wastegate Tial Blow off valve 12x24x3 Intercooler Mac valve boost controller Stainless Steel AN wastegate Lines Cooling system 3 core aluminum radiator Twin 12" SPAL fans wired to relays Solid upper rad hose TRD Rad Cap Suspension and Wheels Ksport coilovers Work VS-SS (NOT INCLUDED) 18x10.5 +24/29 Moog Rear Camber Arms Interior Reupholstered Blue Leather Momo steering wheel HKB Boss hub Oem toyota radio Glowshift boost gauge https://www.flickr.com/photos/[email protected]/ Last edited by S13-A70; 02-14-2020 at 04:28 PM.. Reason: Wheels no longer included with sale |
