Hello, this would be my first post and I’m still getting used to this forum and how it works. So bare with me I’m sure I’m doing some noobish nonos already. Anyways, I traveled from L.A. to Sanfran and purchased a 91 s13 Coupe that was originally automatic I believe (which is why I’m slightly confused because I’m getting some different answers) . She has a 95 S14 KA24DE swapped in (Yes it has that bolt at the back of the head near the firewall) and it’s now a 5 speed. Can someone direct me to a thread or help me here that explains a bit about the sensors for a 95 swapped into a 91? My TPS is getting stuck at 3K RPM every other red light and I end up having to get out and reset the throttle body cable. I also need a new coolant temp sensor along with a new pigtail since my pigtail is cracked causing my temp to jump around while I accelerate. Thanks !
~ Mvrdoc |
![]() Join Date: Jun 2005
#/f/showthread.php?t=180073
Would want to know if they used the s13 or s14 engine harness when they did the swap. |
#4 | |
I bought my '92 with a 5 speed swap, and frankensteined KA already done, so i dunno every nuance of the swap. I think mine is a s14 block mated to the s13 head, but i don't have a SCV, or any butterfly valves in the IM which is confusing. I can tell you 100% that i'm running a s13 harness and ECU |
#7 | ||
![]() Join Date: Nov 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
and welcome to the forums Quote:
The Game you lose haha |
| 91shell, 95ka, engineswap, kaswap, sensors |
