Old 11-06-2008, 07:01 PM   #1
hoclifford
hoclifford is an unknown quantity at this point
What the hell is wrong with my camber? Or is it not my camber?
My camber was pretty whack when i first put ont he wheels. One side was tucked the other was sticking out of the fender... wtf? So i got it aligned thinking itd all be good. After alignment my front was camebered out to -3.5 both wheels were nicely tucked under the fender... awesome...
But then now i have a bigger problem it seems that my whole wheel moves? Back and forth on the camber axis, or so it seems. Basically i mean it looks like its negative sometimes and then other times horribly positive. And no its not because of the ground ive checked it multiple times on the same flat ground and have had multiple results. My camber plates arent loose and do not move. What can this possible be? Take a look at the photos below im sure you can tell what im talking about.
Bad...
Slightly better... Sometimes it sits more in.. meaning more negative camber.
Does anyone have any idea what could be wrong? Last time i had it up on a lift people told me everythings tight... Meaning my arms and stuff.. Could i have a deformed tire? bent rim? but if that was the case wouldnt i feel it when i drive ie. crazy vibrations?
hoclifford is offline   Reply With Quote
Old 11-06-2008, 07:08 PM   #2
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
is that the front or back of the car...check the hub could be messed up also check to see if any lugs are loose or the wheel isn't even sitting on the hub correctly.
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 11-06-2008, 07:10 PM   #3
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
Check for play in your wheel bearing. Also check to make sure your coilover to spindle bolts are tight.
LayNLow is offline   Reply With Quote
Old 11-06-2008, 07:13 PM   #4
hoclifford
I just installed BRAND new ichiba hubs. im assuming they were good when i slapped em in... and the spindle bolts and lugs are definetly tight.... I checked those already.
Old 11-06-2008, 07:16 PM   #5
murda-c
murda-c's Avatar
camber plates moving around?
Old 11-06-2008, 07:18 PM   #6
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
jack up one side shake the wheel and look underneath to see what is loose. alignment guy was probably an idiot n left somethign loose
parking lot pimpin...
Seller Feedback here:
#/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 11-06-2008, 08:04 PM   #7
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
did u replace em bearings on the hubs? they will go bad sooner than later
lexus baby
5t341tH is offline   Reply With Quote
Old 11-06-2008, 08:09 PM   #8
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
retighten the bolts on the shock mount bracket.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 11-06-2008, 08:16 PM   #9
sidewayzsx
sidewayzsx has a spectacular aura aboutsidewayzsx has a spectacular aura aboutsidewayzsx has a spectacular aura aboutsidewayzsx has a spectacular aura aboutsidewayzsx has a spectacular aura aboutsidewayzsx has a spectacular aura about
dang thats weird, check your coilovers
sidewayzsx is offline   Reply With Quote
Old 11-06-2008, 10:56 PM   #10
hoclifford
I Know ichiba's bearings aren't known to last very long... but i installed them less than a month ago... my camber plate doesn't move at all. I even marked it to make sure. i havent had the time to lift it and really check... and if i did i couldnt check much anyway cause i lost my rays lug nut key and am waiting for my new one to come... (drove the car with it on..)
But the car makes no clunking noises at all in the front, just clunks from my 2 way.
Old 11-07-2008, 05:44 AM   #11
Ali 556
Ali 556 is a well-known jackass
take the front struts off...and hold the camber plate with one hand and try to wiggle it around...if it's easy to move/ play with...your TOP bearing in the coilover is shot...
if so PM b/c i know the guy how sell new bearing to replacew the old ones
or check here :
ball joint (?)
strut UPPER bearing (the one in the CP)
hope this help,
Ali
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 11-07-2008, 08:06 AM   #12
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Quality TC rods?
were the rod end bearings were properly aligned?
I have known cheap ones to come loose.
Old 11-07-2008, 08:16 AM   #13
SoSideways
SoSideways's Avatar
Nobody even mentioned the FLCA bushing, or ball joint being shot?
I've had a ball joint go bad on me when I owned a Z32, that was kinda scary... Wheel would seem loose from the bottom when the car's jacked up. You can literally sit there and wiggle the wheel.
Old 11-07-2008, 11:47 AM   #14
Ali 556
or check here :
ball joint (?)
hope this help,
Ali
Old 11-07-2008, 11:52 AM   #15
SoSideways
SoSideways's Avatar
You mentioned the ball joint, but didn't mention the FLCA bushings.
1 out of 2.
Not bad.
But no cigar.
Don't twitch your eye at me.
Old 11-07-2008, 11:59 AM   #16
ericcastro
ericcastro's Avatar
Are you running spacers??
A buddie had this happen at the track, we thought it was a bent rim.
Turns our there was a little hub washer type thing that was behind the rim and not seatring right.
Old 11-07-2008, 12:10 PM   #17
SoSideways
SoSideways's Avatar
A rim not sitting right over a hub ring would cause the wheel to be completely not sit on the hub straight, causing the rim to wobble badly, not to mention you wouldn't be able to put the lug nuts on correctly either...
And I'm sure the OP has at least driven his car around like that, which, if the wheel wasn't even installed correctly, I'm sure he wouldn't have made it down the block before the wheel fell off...
Old 11-07-2008, 12:21 PM   #18
AznDrftr.
AznDrftr.'s Avatar
AznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond repute
Send a message via AIM to AznDrftr. Send a message via MSN to AznDrftr. Send a message via Yahoo to AznDrftr.
i've got the same problem, but its more or less probably cuz i hit a curb and something is shot.
AznDrftr. is offline   Reply With Quote
Old 11-07-2008, 12:30 PM   #19
S14DB
AFC #1
S14DB's Avatar
Did you hump the fender while a friend watches for anything moving?
Old 11-07-2008, 12:37 PM   #20
rhd_sw20
rhd_sw20's Avatar
rhd_sw20 is a name known to allrhd_sw20 is a name known to allrhd_sw20 is a name known to allrhd_sw20 is a name known to allrhd_sw20 is a name known to allrhd_sw20 is a name known to allrhd_sw20 is a name known to allrhd_sw20 is a name known to allrhd_sw20 is a name known to allrhd_sw20 is a name known to allrhd_sw20 is a name known to all
I say its your strut to spindle bolts that are loose, its a common camber adjustment from factory on vehciles. If you have smaller inner diameter bolts, it allows for adjustment of camber, and if you say your camber plates are tight, I would look in this direction.
rhd_sw20 is offline   Reply With Quote
Old 11-07-2008, 06:51 PM   #21
hoclifford
Thanks for all the useful comments guys. I will check out everything mentioned above tomorrow when i bring it to a shop nearby.
