i have a s13 sr20det with a bottom mount gt2871r and a Z32 MAF, in an s13 body, i want a hard intake pipe and my apexi wouldn't fit, it hit the reservoir that is mounted on the fender, i think its for tranny fuild, so what hard pipe would fit?
![]() Join Date: May 2008
i relocated my manual transmission reservoir to the passenger side, next to the windshield wiper motor. just had to run a couple new lines to the tranny. but i had a T25 KA-t, with identical intake setup like your running. not sure how much of a difference there is between the two engines, but i ran into the same problem
![]() Join Date: Aug 2009
I've never seen manual tranny fluid reservoir outside tranny in my life. Do You guys know what you are talking about?. I just use 3" pipe and hose for the intake for my gt2871r
I actually think it is power steering, it is the little tank on the driver side shock mount, I can get the stock rubber intake to fit but I want a hard intake pipe because I have the z32 MAF now
![]() Join Date: Jun 2010
Do you have the compressor housing with the bolt on inlet pipe? If you are trying to use an intake pipe designed for an S13, it won't work without clocking plates. You can force the rubber boot into place without using clocking plates, won't be perfect though.
#18 | |
ugh i'm not the only one who was thinking "wth is the trans fluid reservoir" lolol... i ws thinking all my life was a lie lolol
You can sleep in your car, but you can't drive your house. |
#21 |
