Quick help pls. Dropped Plastic bit in my intake.
Hi.
Was changing injectors on sr20. Little useless plastic bit of injector had come loose. Idiot me tried to fish it out but instead it fell in the intake. Price is about 5mm high 8mm diameter. Removed the fuel rail, as I should have done straight away. Can't see it, can't really fish it out. Don't know what to do. I'm thinking worst-case scenario if I say fuck it is that it gets stuck in the valve open and valve fucks the piston. Advice please. |
pintle cap?
take the intake/intercooler cold pipe off and try to use a shopvac to suck it out through the throttle body (make sure its open). worst case scenario take the manifold off and shake it out. If it fell into the cylinder you could remove the spark plug and try to extract it with the age old "gum on a stick" type trick. If its in the cylinder but you can't see it, you could try agitating it by blowing some air in there with the compressor. Another way would be to roll the engine over until an intake/exhaust valve is open and blow air through the spark plug hole at, idk, maybe 70 psi and probably blow it out. Maybe even vacuum the TB while blowing air into the spark plug hole. |
Yeah the pintle cap. That's great advice. Only problem is the car is not near a outlet. Since changing the injectors is eminir job only requireing like two tools I didn't bother driving it up to the garage... In hindsight I highly regret it. Walked probably a mile to and from the fucking car.
![]() Join Date: Jun 2003
dude I would NOT run the car with a chunk of plastic floating around.
Get tools, remove the intake manifold, find the chunk, remove it. even if it DOES pass through the cylinder, do you want it bouncing around in your turbo? I get that its only plastic, but still. |
#9 | |
I'd like to think i'd exhaust all possibilities of removing it instead of just hoping it would be fine. |
#10 | |
And here I thought somebody was going around, removing them Blind! So blind. It turns into a snack! Of course it does |
| Tags |
| injector, sr20 |
