messed with idle now motor shakes
latley my auto s13 (ka24de) has been having a idle problem it get a really low idle i read and learned that there is a idle screw. i turned it out trying to make the idle higher. now when i start the car at get it to about 2000 rpm the motor will start to shake pretty hard. if i let off the gas it will idle but the rpm needle will go from 1000 to to about 1100. i tried to drive and when the car would shift into 1st gear it would jerk pretty bad. could it be the atf?
#4 | |
now i get a weird noise coming from the engine. if you can imagine the oil cover broken into pieces rattling thats what it sounds like. im thinking its the chain guide. |
![]() Join Date: Jul 2008
Trader Rating: (26)
![]() ![]() Feedback Score: 26 reviews
take the vavle cover off. remove the upper chain guide if you haven't yet. check the cam lobes to see if the lifters are bouncing. or try using some lucas oil stabilizer.
