To start off. I have a 1992 Nissan 240sx ka24de 200,000 miles. Car ran perfect when I first bought it. 6 months later it takes a fail on me as I’m driving. One misfire then maybe 100 feet later shuts off and all the idiot likes come on. Doesn’t hesitate like it has no gas it just completely turned off no hesitation. I try to start it but it only cranks. I get a tow home and next day I go to to start it and it runs. I drive it for 5 minutes and same problem but with no misfire just shuts off and I have to wait a day to start it again. And now this happens everyday I can’t drive more than 5 minutes without shutting off. So far I have replaced the ignition control module , ignition coil , and spark plug wires. I ran the Ecu and got the codes 34,11,13 which are camshaft position sensor, coolant temp sensor, and knock sensor. Please help I am lost with what to do
I don’t know if this has to do with it. But I put new spark plugs CAuse my old ones looked burnt and they idled for around 5 mins before the car shut off and even the new ones became very black. Not wet
![]() Join Date: Jun 2003
Trader Rating: (129)
right, so you guys, if you are NOT getting spark, check the EGI relay.
make sure it is engaging. I've seen a number of Nissan ecus that fail, and will not trigger the EGI relay to engage. |
of course. if it clicks on and sends power past it, its good
if it doesn't click on and send power past it, its bad if it does either of those things intermittently, its bad want me to come help you brush your teeth too? |
I mean, unless you wanna buy me a flight to philly, you're gonna hafta do some of this diagnostic work yourself. Go check your relays, get a test light or power probe or multimeter to check for power across the switched side of the relay, then next time it fails, check it again and make sure you confirm the results.
#16 | |
#17 | |
#18 | |
#19 |
![]() Join Date: Jul 2005
you need to put the $5 multi-meter on the ECU power / EGI relay output
and have the meter ready for when the engine shuts off to verify the power is gone or not if not, continue to use the meter to complete diagnosis by checking each circuit until isolated the problem "shutting off" suddenly is likely: 1. 1 or more relays failing (replace relay indiscriminately) 2. fuel pump failing or sudden fuel filter clogging (check fuel pressure during issue) 3. fuses can be 'bad' suggest also changing fuses at 'random' (change the ones you think might be associated just for the heck of it) 4. loose wires, plugs, loose ECU connection, (check ECU plug, check ALL wires, pull on them while testing CONTINUITY with $5 meter For #4 study factory service manual diagrams, follow the power from battery to the computer/injectors/distributor/etc... so you know instinctively which circuit gets power from where, when that power should be there, etc... for example I believe the injectors receive a 12V constant supply (always even when car is shut off) this and other simple 'intuitive' knowledge will aid diagnostics make sure you A. learn how to perform continuity tests using $5 meter B. learn how to test for ground and voltage using $5 meter |
#24 |
tried running a single cam that would do that...found out after my first 20 min drive with it headgasket was gone and there was no water in the system...but the diagnostic above looks pretty good too!
#25 |
If one of my coolant hoses (under intake manifold) is kinked and not letting anything through could this cause the car to die? Also I noticed that my car only dies when I put it into gear, fuel pump maybe?
Ka24e SOHC |
| distributor, ecu, nostart, spark |
