![]() Join Date: Aug 2012
Trader Rating: (134)
![]() Feedback Score: 134 reviews
90 240sx hatch part-out 5 lug X's 4, J30 diff-axles, q45 z32 brakes
Hey guys, well I bought this car last night for a couple parts to use on my project car. I have sold quite a bit already before listing this part-out. I'll list off whats been sold so you dont have to question if its still up for sale but if you do, please send me a private message. Im willing to cut any part off the car you need, (IE) rear quarters, roof, pillers, spare tire well, etc; etc. Im Paypal ready, obviously everything listed for sale is still on the car so it will take a few min to remove the parts. If you have any questions send me a private message.
Thanks ![]() Pending sale: Sold: Piggy lip Clutch slave Door panels Gas lid/hatch lever and cable Door locks/hatch lock/key Front interior carpet J30 axles Z32 rear brakes Radio/shifter panel Window amp Clutch pedal Brake pedal Lower shift boot with ring Cluster sub-harness Center console Front fenders OEM full sun roof asem; Full left and right headlamp asem;s Glove box with bracket/bolts 5 lug full setup Mint dash Front right leather seat Brake master cylinder Rear sub frame Clutch master Clutch hard line Full fuel system (IE) tank, sending unit, pump, cover with bolts Hood Hood brackets with bolts Sun visors Left and right mirrors Front lower control arms Front sub frame Flca's Full B-C piller panels Full front chassis harness Rear quater glass left/right Hatch lid (wing/wiperless) Roof Full front wiper setup (IE) linkage, arms, wiper amp, motor, cowl cover Front bumper Front j30 brake calipers/brackets/pads/lines/rotors Rear carpet with bulb panels Full front seat belts Rear seats Hood latch Center rad support beam Exterior a-piller panels Full tail lamp set A-piller panels Tail lamp garnish panel Gas lid Speaker backets Speaker panels/grills C piller panels Hatch lock trim panel Privacy cover Left and right kick panels Knee bolter Steering box covers Rear hatch carpet panels Rear hatch lid seal Whats for sale: Again, its a 90 hatch Full ignition cylinder lock with key and sub harness $50 Brake booster $30 J30 differential $130 Hood cable puller with rad. bracket $20 Rear bumper cover with impact bar $20 Throtle cable with gas pedal $20 All brake lines front to rear send me a private message with your offer E-brake with cables send me a private message with your offer Left and right door glass $20 each x's 2 Sun roof head liner $30 Dome light asem; $10 Rear view mirror $10 Rear seat belts $30 Steering setup (IE) steering column, rack, etc. send me private message with offer Full a/c lines and condenser $80 Cluster $30 Cluster bezel with all buttons $30 Full in cabin chassis harness $130 Exterior B-piller panels $40 Im sure I forget a few things but this should be a start! New pictures:
Need some parts? Send me a message!
Sent private messages to all of you, thank you ![]()
#9 | ||
J30 axles, Radio/shifter panel, Window amp, Clutch pedal, Brake pedal, Lower shift boot with ring, Cluster sub-harness all sold!!!
#12 | |
#15 | |
Thank you very much!
#18 | |
#28 |
Mint dash sold!!!
No longer pending sale on these parts: Brake booster Clutch master Clutch hard line J30 differential Q45 front Z32 rear brakes
