![]() Join Date: Feb 2002
Enjuku Racing - Pro-Series Fabrication Dual Caliper Bracket for Z33 350z/G35
![]() ![]() Pro-Series Fabrication Dual Caliper Bracket for Z33 350z/G35 In Stock and Ready to Ship! $329.99 ![]() Pro-Series Fabrication Dual Caliper Bracket for Z33 (Accepts Brembo and Non Brembo Calipers, retains factory E-Brake) Kit uses either factory Nissan calipers or Brembos Retains factory emergency brake CNC machined from 6061-T6 and comes with grade 10.9 hardware ![]() ![]()
Hello there,
My car is a Basic 2003 Z. I'm using OEM calipers for both pairs on the rear. After putting everything back together the extra calipers don´t fit right. The calipers there were already in the car work fine after the dual caliper brackets were installed. I used the 35mm bolts and the spacers to install them. The problem are the extra calipers. They lock the rotors. The bracket of each caliper touches the rotor and it get stuck. The extra calipers came from a 2006 350z. They look slightly different in design but the same in dimensions. I´m also using OEM brake pads. Even without the pads the extra calipers lock the rotors. The weirdest thing is that everything is aligned. 2003 OEM Caliper using spacers > Dual Caliper Bracket > 2006 OEM Caliper Have anybody faced the same problem? Or could give me some help? Thanks. |
