sr20det no ground injector 3
I am just curious which pin is the ground wire on ecu plug for cylinder three injector to see if there is any continuity. I have 12 volts on power side. I am suspect of the ecu which is JWT chipped but i opened up case and didnt see anything burned and no electrical burn. So I want to test to see if there is a break in wiring harness ground to cylinder 3
